  • SN95 4.6L Mustang Tech
Lean ??
  • Thread starter Thread starter phoenix99
  • Start date Start date Aug 8, 2008
P
phoenix99
63
Quebec
Aug 8, 2008
  • Aug 8, 2008
Hi, I've plugged my wideband on the driver side exhaust and the reading is around 15.5 - 14.5 at idle, 15.0 14.3 acceleration and 14.7 13.5 at wot
I've a mac prochamber and no muffler... I've read somewhere that a no muffler setup can cause a lean reading but is it true? Should I buy a set of muffler?
I want to spray wet nitrous but i'm a bit scared to spray if it's lean before spraying...
Thanks
Stark77
501
Tallahassee, FL
Aug 8, 2008
  • Aug 8, 2008
if you have a handheld tuner you should be able to bump up your A/F ratio 3% or 4%
bhuff30
6,037
35
129
Olathe KS
Aug 8, 2008
  • Aug 8, 2008
That seems a bit lean all over. Cruise should hold a pretty steady 14.7. On my stock 97, on a WOT run in 2nd or 3rd, it is around 13.5:1 till 3500, then starts dropping to 12.5ish:1 by 5500. Mufflers should make no appriciable difference in AF ratio.
Try cleaning your mass air meter. When they are dirty or coated in oil, they will read low, causing a lean condition.
As for spraying, you can change the jets until you are happy with the AF ratio. If you think it is too lean, then just put a size bigger fuel jet in. You can buy jets in increments of .001 or something, so you can certainly get the AFs where you want while spraying.
98COBRA281
1,348
30
59
Port St. Lucie, Florida
Aug 8, 2008
  • Aug 8, 2008
yeah that seems rely lean, at WOT 3500-6k, my a/f ratio pretty much flat lines at 11.7
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
"Tuning" Vortech kit with FMU discs- question
  • nicholase
  • Jun 22, 2024
4K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 13, 2025
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
J
89 2.3 LX running rich, hesitation on acceleration, high and hanging idle Help!
  • jpstucky
  • Jun 13, 2023
  • 2.3L (N/A & Turbo) Tech
3K
2.3L (N/A & Turbo) Tech Jun 15, 2023
jpstucky
J
