I am going to start focusing on my old Ford again.
I have a Maverick... never could seem to afford a Stang.
I hang out here because so many parts are the same and most things that apply to a 65-66 (dimensionally, weight, shape, etc...) apply to the Maverick, so I tend to watch those posts.
Anyway...
I keep modeling different engines on the puter and I cannot build an engine that averages more torque or hp below 6000 rpm with aftermarket heads.
I get the flattest, highest, and 9 of 10 times best peak to 6000 by using ported early 351w heads (1.94 valves).
As soon as I model larger valves or any aftermarket head in the database, the power average, and most of the time, the peak hp drop drasitcally...
Remember I am modeling up to 6000 rpm, after 6k it is a different ball game and the ported iron heads get whipped like red headed stepchiles.
I have never built a 351w, normally I would expect to spin higher as I have always been most into SBFs or Clevelands.
So this has me floundering a bit.
I am torn between 3 setups:
1: 351w with 400 rods and all the goodies. (Models to 540 hp @ 6000 with ported stock heads, numbers get worse with aftermarket because of too much flow.)
*I have always wanted to build an ultra long rod engine for giggles.
2: 393 with all the goodies. (Haven't modeled YET, but look at the price advantages.)
3: 408 with all the goodies. (Again, pulls better numbers with said iron heads until 5.5k. This one will pull a better peak with aftermarket heads, but only slightly... Average torque and hp are still low though.) This engine will pull the exact same power curves as the long rod 351, just 40 hp higher across the chart.)
So...
Let's discuss:
Is it a waste to put fancy heads on an engine that you don't want to turn over 5500-6000 rpm?
Is the computer model missing something? It seems very comprehensive. It is Engine Analyzer 3.0 and I find it much more informative and exact than Desktop Dyno. I have used both. You can enter far more varibles with EA.
Also, I will note that the heads that are getting the most power are 69-74 351w heads with Chevy valves and porting to the max. NOT stock heads... stock heads model miserably and choke out around 4.5k rpms!
Ideas?
Thanks
Dave
Anyway...
So...
Let's discuss:
Ideas?
Thanks
Dave
