Let's discuss aluminum heads... BTW: Dumped the Chevy
I had him until he reminded me about the under 6000 rpm tidbit. This motor is turning 8000 on the indexed '65 cast crank in the '65 2 bolt block with no girdle, just a windage tray, with stock length Howards Aluminum rods with a V6 Chevy big rod end (what size is that?) and some heavy TRW 12.7:1 pistons (which is about 11.5:1 with the '69 351w head).
I never dyno'd it, but I'm pretty sure it's REALLY close to 500hp at the flywheel, if not over it. The shortblock is now wearing a set of out of the box Canfields and a Funnel Web intake with a ProSystems 850DP. The rods probably have over 200 runs on them and have never been re-bearing-ed.
:jaw:
Welcome my Maverick brother. Join us on the Maverick boards. I can give you the URL if you need it.
First, I don't trust the computer models on a lot of these things. Real world dyno tests have proven them wrong time and again, as mentioned above.
Also, people tend to fixate on intake flow numbers for heads, but the real gain in aftermarket heads for small block Fords is on the exhaust side. I look at exhaust numbers first, as there are very few Ford heads where the intake flow can't keep up with the exhaust side.
I have seen a number of dyno tests and it seems the average performance increase for each point of compression is approx. 4%. Of course, when you step up from 8:1 motoors to 11:1, you have to change cams and flow characteristics to make it work, so the numbers can be variable.
never said that stock casting heads wont perform either just alot cheaper to do it with the aftermarket stuff and dollar for dollar stock heads cant match up! 1320 stang I bet that car is going just as fast if not faster with those canfields on there, spend some money on them and go lots faster than those 351w heads ever let you go!
Max Power said:
Welcome my Maverick brother. Join us on the Maverick boards. I can give you the URL if you need it...
Yeah, after ignoring the Mav for years, I am starting to do things to it now that I am not distracted by the Chevy anymore.
The roof rotted out on the car. :(
It came 30 years ago with the 3/4 vinyl top, I had 15 years to get a brain an take it off to prevent the problem I have now, but didn't do it until it was too late.
I have some pin holes in the passenger rear floor pan, but other than these 2 things, the car is rock solid.
I am going to weld up the holes in the pan and my uncle has a parts Mav with a solid roof, so I am confident it will come together.
I am going to go slow with it.
Before, I ignored body work all together and my engines made good power, but were never nice to look at like so many ultra clean engine compartments some folks have on this site.
Body comes first for once, then the rest is going together with perfection as the goal. :)
What sites do you travel for Mav info?
I have 1 that I have been creeping around quietly for a few years... maverickcomet.to
It's a slow forum. Nothing like stangnet. The latest message in a forum might be days old at times.
Dave
Nope, slowed down, but it's running street radials and a 4.33 gear with a transbraked PA C4 and a 4500 stall.
But I can tell, it doesn't make as much power. Maybe if it had the tunnel ram and 660's on the Canfields. I gave $2150 for the 289 and no intake or carbs, have another $500 in those. Pretty stinking cheap. It would have run 10's if we had new slicks.
