Lets see some HIDs
www.misterjung.com
I have the 7000K kit, starts up purple, warms up to WHITE (I mean really f'n white, makes the HID's on an Escalade look yellow). If you at the headlights you might be able to see the *slighest* touch of purple in the lights.
I'll get some pics/vid tomorrow......used to have some but I guess I deleted them.
SMRcalidiv said:
ok, so you have the 7000k thats the plug and play one? there are a ton of lights on that page...what was involved in the install and how much did you pay?
$400
Install was pretty simple. Took a little longer than it needed to, mainly because I didn't read the instuctions completely. :bang:
The hardest part is just figuring out where you want to put the ballasts, which is only time consuming if you're anal.
There's a power and a ground wire that goes into the connector for the headlight, that goes into the ballast, then a harness comes out of the ballast and goes to the bulb.
Our cars use the 9007 bulb (pretty sure on that, you can double check on a site like Sylvania's).
SMRcalidiv said:
yeah it is the 9007. do you have any pics of the install. also, does the kit use our existing harnesses?
No pics during the install.....it does come with a good manual though.
No need to modify the harness or anything. The "harness" really only is a plug that the stock headlight bulb just plugs into.
if im not mistaken the headlights actually run cool to the touch, something about the way they operate :shrug: , the reason i asked about the harness is that one of mine got 1/2 way melted and it needs to be replaced, i just thought id kill 2 birds... anyway, does anyone else have an hid kit with pics?
