final5-0 said:I've been right with you and agree with all you've said up until now, so maybe I'm not understanding what your saying but....................![]()
My point was that unless his combo gets close to the 300HP level and is running lean at high rpms, or pegs the MAF, that he wouldn't need to upgrade to 24# and a new MAF. I guess I didn't say it that well. I don't have a problem with fuel pump upgrades, I just don't see most people needing more than a 155lph pump. The below calculator says that a 155lph pump will feed an engine up to 500HP. The stock 94-95 90lph pump should support up to 280HP, flywheel not rear wheels!
Here are some fun calculators.
http://www.hardcore50.com/members/calculators.htm
I'm over here some times.
Thanks a bunch Grady! I suspected 24's would not be up to par for my setup, so I decided to go with some 30's. I bought some FRPP 30's today on eBay for quit cheap too. I will DEFINITELY be getting a custom tune once I get my MAF recaled (can't use my injectors til that happens
). Until then, I'll run stock 19's and bump the fuel pressure to around 60. Hopefully I won't have to do that for long, but we'll see. Thanks again!
