The failures were limited to flat tappet cams. Ain't heard of any roller failures. The two failures I had were really due to the lifter not getting rotated by the cam lobe. That was due to one of these two scenarios: poorly machined lifter face (the proper lobe face on the lifter bottom is slightly convex) Too much or too slick or thick of a lube between the lobe and lifter, thereby not allowing the lobe to get enough traction to spin the lifter in it's bore Tthe Crane failure was at initial startup in low 30*F weather. With the Comp cam failure, I litterally slathered the cam and lifters with moly lube. With both replacements, I only applied a thin film of lube on the lobe and lifter bottom to protect each at startup. I used motor oil only on the lifter sides and bores. I also verified the lifters spun freely in their bores when each was dropped in place. Both these failures happened in the first 20 minutes of run time. A retrofit roller is expensive, but then again, so are cam failures. Just me, but with a SBF, I just start with a roller block and avoid the extra expense
