lifter problem
  • Thread starter Thread starter pa308
  • Start date Start date Jan 26, 2006
P
pa308
45
  • Jan 26, 2006
i have an 84 351w The other week i fired it up and heard what i thought what a loose rocker. Welp wrong.I took off the valve cover n fired it up no5 had no oil coming up n i seen air bubbles. I changed the oil n it went away Whats the deal it does have 214k on it
bill302
2,131
alabama,gadsden
Jan 26, 2006
  • Jan 26, 2006
sounds like a little sludge after that many miles her arteries are what they used to be. what type of oil do you use and how often do you change oil. how did it look under those valve covers no sludge a little or what.
Black1987Stang
1,422
Jersey Shore
Jan 27, 2006
  • Jan 27, 2006
also sounds like ur oil filter...wouldnt be surprised if it was a Fram
Exact same thing happened to my friend 2x, one time it was the exact same with u (started up in morning and no oil pressure) he changed the oil filter and it was fine except he put on another Fram ...the other time we were at the mall driving around fine, turn the beast of a 2.8L off for not even a minute, start her back up and sounded like there was a midget inside smacking everything with a hammer, no oil pressure at all!!! Both times were with the fram oil filter and as soon as he changed it everything went back to normal, he put on a different brand and its been fine ever since...Im betting it was ur oil filter
Just reread ur post, saw only #5 wasnt getting oil...couldve been lifters or sludged up pushrods or something like that
P
pa308
45
  • Jan 27, 2006
i use 20w50 castrol regular oil.I use 5 and 1 quart of lucas also a fram filter are they junk or what.
Sicarius428
2,085
Jan 27, 2006
  • Jan 27, 2006
Yeah, fram is pretty much the worse filter out there. Motorsports, Mobile 1 and K&N are a couple of the best filters out there. Try sticking to those.
Kevin
P
pa308
45
  • Jan 27, 2006
thanks its weird i always used them n they were fine. everyone on here says the same FRAMS R JUNK
352Ford2
393
Seattle,WA
Jan 27, 2006
  • Jan 27, 2006
The fram PH8A does not have a anti drain back valve, so depending on the angle you oil filter sits the oil drains back when you stop the car and you get a dry start next time
I beleve the "better" frams have one (DG8A)but I can't remeber and don't really care that much.
I love Wix 51515's
cheap and good
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
G
Engine Pushrod Length Question
  • germain101
  • Sep 22, 2025
Fox 5.0 Mustang Tech Sep 25, 2025
