Lifters for my 331
Andres2882
316
Do I need hydraulic roller lifters or just roller lifters? What factors decide which of the two that you need? I really don't know anything about these parts, so any help would be great.
The cam that you purchase decides that.
The ramp up / down profiles are different between
Solid cam
Hydraulic Solid
Solid rollor cam
hydraulic roller cam.
If you motor is original, you have a hydraulic roller cam. Which means you have hydraulic roller lifters and most OTS cams for the big companies will be set up for hydraulic roller.
Andres, I have used a lot of the Ford lifters with no issues, Summit sells them for $120. Unless you are going solid roller, those lifters will be just fine.
Thanks Rick, those are the ones I was looking at. I didn't know if I needed the rolling lifters or just the $100 hydraulic lifters. Thanks for the info everyone.
On a sidenote, I finally got around to installing your torque box reinforcements Rick, all I can say is :nice:
A lot of people say roller lifters when they are talking about hydraulic roller lifters. When people start talking about roller lifters for a mechanical roller cam they tend to specify mechanical roller lifters.
