Lightening Maf Wiring
90GTFIVO
120
15
29
Carroll, OH
I'm thinking of swapping my Pro-M 75mm MAF (calibrated for 24# inj) for a 90mm LMAF. I'm installing 60# Siemens Deka injectors and will need to have the sensor calibrated. So I have 2 questions:
1. What wiring modifications will I be getting into?
2. Is it as easy to have Ford calibrate the MAF as it is with Pro-M (simply mailing it in to them)?
Also, what other mods am I missing? Will this require an adapter plate?
I hate to thread jack but my question is can I start the car with thelightning Maf and once its running I can trailer it to my tuner just wondering
Not likely...
If the air/fuel ratio isn't within range you're going to have problems getting it to start and keep running.
42s the maf and injectors are off the same truck
Don't think it's going to work Mike. If you had a MAF calibrated for an A9L and 42s it would likely start but run like crap and pig rich. With the LMAF --and--42s... you're pretty much out of options. The A9x doesn't like the LMAF without a transfer curve and it doesn't like 42s without injector slopes.
Plan on trailering to the tuner.
