Lights cut out
I went out for a ride in my 91lx and about 10 minutes after I left my home my head lights, parking lights, and interior lights went out. I do not know if the tail lights went out. I moved the headlight switch to off and back to on and everything worked again. Then about a hour later my interior lights went out. I moved the switch to off and back to on and they came back on about 2-3 seconds later. Then everything worked fine for the rest off the ride. I use this car as a daily driver and I never had this happen before. What could it be ?
pop you headlight switch out and check for burnt or loose connections! put your nose by the light switch and take a sniff! do you smell electrical? these cars are notorious for the headlight wires frying behind the switch! just a thought that's what happened to me with my old fox! the wires were frying !
mustanglx91.... My guess is its an lx.... a 91 :D but the switch and wires are most likely the problem as stated above.
Edit: just re read that, I wasn't trying to poke fun or make anyone sound stupid. Just stating that he joined in sep 07, and thats his name.
Oh ****
There is a trick on these cars at the front bumper and I can't remeber what it is. I know it's reachable by hand and it's a common problem. 2 guys I know had the same thing happen and it was the same thing- I'll ask for ya :nice:
