Kilgore Trout said:I heard these are pretty light, not sure exactly how much they weigh though...
san~man said:There was a wheel weight thread a while ago....do a search and see if you can find it.
Torinalth said:
DropTopPony said:I like the konigs
Venom_Nitrous said:-1lb of rotation mass = -10 lbs of static mass.
[Twitch] said:Yep, 28lbs Bullitts vs 17lbs 5zigen for example will shave 11lbs each wheel. If you add linear and rotationnal torque difference required for the new wheel weight, you will save around -101.19lbs in chassis weight equivalent.
And that's comparing a 17X8 with 245/45/17 to a 17X9 275/40/17
RAT said:Sorry but your number are not correct. You need to look at the rim and tire together as a good comparison. ex. My 17X8 Mach 1 wheels and Gatorbacks are a total of 50 lbs per corner. My autox combo is 17X8 rim and a 275/40 tire are a total of 45 lbs each. Total weight saved = 20 lbs. From documents I've read, for every 1 lb of rotating mass you remove, is = to 6 lbs of static weight removed. In my case about 120 lbs of weight savings from the 20 lb lighter wheel/tire combo.
Here's more info on this..
http://www.svtperformance.com/forums/showthread.php?t=223790&highlight=lbs
Here's some 17X9.5 for 15 lbs http://www.thethrottlestop.com/wheels_halibrand.shtml
Bogart has some light wheels also.
If you tried it, you would see the same numbers...[Twitch] said:I am using the same spreadsheetIf you tried it, you would see the same numbers...
If you want to compare same exact size rims and tires(17X8, 245/45/17), if comes out to exactly -100.68lbs. 54lbs for the Bullitts and 43lbs for 5Zigen.
