lincoln 24lb injectors
stykthyn
5,232
2,652
223
gainesville
I have two sets of these 24lb injectors. one set is from a 93 markVIII and the other from a 95 continental. both cars had the 32v 4.6.
are these injectors worth running on a gt40 based motor or should I stick with 19 injectors?
I just heard some crazy story that the spray patterns were different than injectors for the mustangs. I was also looking at the 19lbers that came from my explorer motor and they have the four holes in the bottom instead of the needle that is on the 24lb injectors that I have.
Ford/Bosch/Denso changed from the single hole to the 4-hole at some point. They all work the same. The 4-points are supposed to be slightly better at spraying the fuel correctly
