My guess is that on that car, the wipers are controlled by one of the electronic modules. Some basic troubleshooting is a good start, such as making it fail, and testing to see if you have power at the motor. Also check the fuses.
If there's power at the motor, then it may be the motor. Remember it is a multi speed motor, so one speed may still work.
Also note that there is an interval governor function (delay box) also controls power to the motor when in that mode. It should be in the same electronics that control the wipers and washer. I am not sure but there may be a relay to power the system due to delay when shutting the car down, like the lights. If so, check it.
Painful, but some testing is in order, as opposed to parts changing, I would think, as this system has a good bit of controls.
