Line Lock as a Security device
If I used a toggle switch on front-brake line lock setup, what problems do you foresee with my pressing the brake pedal, putting the toggle into the "ON" position, and walking away from my car ?
Will this damage the solenoid ?
Will it result in a drain on the battery ?
Just wondering if aside from the typical usage of this device, if it could also be used as a Security device.
Any feedback is greatly appreciated.
-D
What type of solenoids are they? I have a lot of experience with Solenoids from Air Suspension and it shouldnt really put that much of a pull on the battery at all. Its not really the best Anti-Theft solution, but I suppose it would work. I wouldnt bother personally.
Edit: I must have put thousands of cycles on my solenoids on my truck, no problems whatsoever, and this was with 200PSI behind the valves being held shut. Might be a different type of valve setup though.
B&M 46075 Line Lock Loc Launch Control Solenoid
I should have been more clear.
The car will be garaged, but when I step out to a restaurant or something like that, I thought it would be "nice", not necessary, to lock those front wheels down.
