I actually know how to do it, its just such a tight squeeze that I wan'ted to see how some of you guys routed the new lines.
stang951, you need to disconnect the single line going to the bottom of your master cylinder. You need to plug the master cylinder. run the open line you just disconnected to one of the 'outputs' on the line lock solonoid.
next, disconnect one of the lines that goes to the bottom of your prop. valve (disconnect the line that runs to the right front wheel) You need to then run a new brake line from the prop valve itself to the 'input' on the line lock solonoid. finally, run a third new brake line from the open line that used to go to the prop valve to an 'output' port on the line lock solonoid.
If you have abs, then the instructions are slightly different. if you need them, i can post them.
anyways, still waiting for some pics. thanks again.
