Bad idea? I need something to keep my header bolts from backing out without spending $60 on some locking.
scarless said:Just spend the cash on 1" Stage 8 bolts. Copper RTV on both sides of the gasket. Tighten again in a week.
scarless said:Try what ever you like, not my car, go ahead and try it. If you do a search for header bolts, you will find that this is a very common problem. People have tried all kinds of things to prevent leaks. After trying 2 sets of bolts with lock washers, lock tight, 3 new gaskets, and constantly retightening the bolts, I got stage 8 bolts. Once you've really struggled with header gaskets, you will bite the bullet and buy the bolts.
Zero Signal said:What about split lock-washers?
One needs to heat it a little over 300*F to soften it up for easier fastener removal.eades5.0 said:At that temp the loc-tite will melt
I like saving money, lol. That's almost two tanks of gas!!
CManT1914 said:Yea, Nate I'm with you all the way. Why should I just go out and drop $60 on header bolts if a $6 solution might work?I like saving money, lol. That's almost two tanks of gas!!
