Loc Tite problem
  • Thread starter Thread starter wild70stang
  • Start date Start date Feb 6, 2006
First Prev 2 of 2
1320stang
4,329
23
89
Edmond, Oklahoma
Feb 8, 2006
#21
  • Feb 8, 2006
  • #21
How about removing the sending unit AND the extension and working on it at your bench? that way your not working on it in the engine compartment with chemicals or heat.
BTW, you don't want to get MEK in your eyes, if you do, start planning on what type dark sunglasses you want to wear around all the time since you'll be blind.
I'm a pretty firm believer of wearing safety glasses anytime your working on your car, for whatever reason. I also have a set of those Mechanix gloves, those are pretty nice.
Jsprint68
54
NJ
Feb 8, 2006
#22
  • Feb 8, 2006
  • #22
Don’t want to highjack this but does anyone know how high of a burn temperature Propane is or MAP gas?
Hack
1,945
Minneapolis
Feb 8, 2006
#23
  • Feb 8, 2006
  • #23
I did a quick google and got 2828 C for propane and 2976 C for MAPP, but IMO the MAPP flame seems to be a LOT hotter than propane when used in a hand torch.
Jsprint68
54
NJ
Feb 8, 2006
#24
  • Feb 8, 2006
  • #24
I didn't think it would be that high!
1320stang
4,329
23
89
Edmond, Oklahoma
Feb 9, 2006
#25
  • Feb 9, 2006
  • #25
That can't be right, steel melts at 2400-2800.... Oh, wait, you said Celsus... wait, thats even worse. 2828 C is 5122 F and 2976 C is 5388 F!!!!
Jester67
908
TN
Feb 9, 2006
#26
  • Feb 9, 2006
  • #26
http://bernzomatic.com/bernzomatic/consumer/jhtml/gasTypeComparisons.jhtml
Thats in Oxygen in air Propane is 3,450 and MAPP is 3,650
J
jbuening
399
Feb 9, 2006
#27
  • Feb 9, 2006
  • #27
I don't know about anyone else, but my oil sender extension is aluminum. We all know that standard aluminum melts at much lower temps than steel, so be careful with that heat if you are trying to save the extension.
wild70stang
317
#28
  • Feb 9, 2006
  • #28
I appreciate the advice about propane torches, but if I need a butt load of heat I would use an oxygen acetylene set up. I have used this before to heat up steel pipe and bend it, so I know not to burn through the metal. Now I dont know if the loc tite was put on the extension piece that screws into the block because my dad told me this. My car is 250 miles from me because I am in college, but if all goes well I can take a Greyhound bus back home for $28 . But because the oil sender isnt defective yet, I wont bother with it right now.
Thanks again guys.
Hack
1,945
Minneapolis
Feb 9, 2006
#29
  • Feb 9, 2006
  • #29
Right, and you can use a flame to melt/cut steel. I'm not sure why you think it can't be right. However, I'm sure that a hand torch doesn't get near the maximum temperature of a propane or MAPP flame. Remember that the flame temperature doesn't translate into the temperature of the thing you are heating.
Ever tried to melt ice off your roof with a propane torch? I have, and it doesn't work. There's just not enough energy there. Possibly a tiny point within the flame is very hot, but the torch just doesn't put out the quantity of heat necessary to do much.
J
jbuening
399
Feb 9, 2006
#30
  • Feb 9, 2006
  • #30
No but it will put a nice hole in your roof You would want distributed heat and not concentrated heat to melt ice.
Hack
1,945
Minneapolis
Feb 9, 2006
#31
  • Feb 9, 2006
  • #31
It would have to actually melt through the layer of ice before it could melt the roof. And a propane torch will take forever to even melt through an inch or two of ice.
If the torch put out a lot of heat, you could easily distribute the heat by keeping the torch moving. But it doesn't put out enough heat to require any movement. You can literally hold a propane hand torch up to a big hunk of ice for quite a while and nothing will happen.
Is that clear enough for you or do I have to explain it in a simpler way?
You may laugh, but there are companies in Minnesota that come out to people's houses and melt the ice off their roof. They use larger torches or big steam guns, though.
First Prev 2 of 2
Electrical Issues with my 2006 mustang gt
  • VerneVdV
  • May 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech May 22, 2026
VerneVdV
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
N
Edelbrock 1405 Setup
  • nathantaylor200
  • Nov 4, 2025
Classic Mustang Specific Tech Nov 5, 2025
nathantaylor200
N
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
