Anyone done this yet? It looks to be a billit assy that replaces the existing hard set up with a bolt in assy and a Lkar throttle cable to the carb. Feedback.....
coolblue65 said:very nice, anyone know how much the kit is going for?
Great68 said:Does this "work" appreciably better? Or it is one of those "More money than brains" things?
I modified Lokar's Chevy brake & clutch pedal pads and use their Eliminator floor-mount gas pedal before this stuff came out. I'll probably use these on at least one of the fastbacks I'm building since they're EFI and that's a slick cable setup.monk302 said:Looks pretty nice to me. Clean install as well. Considering that TCP pedal covers are close to $100 (if even still available) I would be interested.
Doesn't Reen install those in his cars?
1320stang said:Aww, dat billut stuf don' mak dat 'turd run no fasta Tod
(hehehe)
bnickel said:if someone wnats a budget version just to get rid of the mechanical linkage the 69/70 pedal assembly uses a cable and is a good option especially for EFI conversions. it won't be as pretty as the lokar setup but it will just as functional.
between the firewall and hte pedal itself?gonzothegreat said:don't you need an adaptor?between the firewall and hte pedal itself?
