lookin for a supercharger
laserstang21
79
luling, La
ok in a month i will be starting a new job and will be makin bout $24 a hour. and i will start saving 4 a charger. so i need to know some sites to look at. i figure a kit with like 8-9lbs of boost, has to come with everything. preferably w/ intercooler. need websites and some prices. i wouldnt mind a turbo cause they come with everything even tubular k member and headers. which tubular k member uses the stock springs? thx for the help
id like to be in the 375-400rwhp range. well im gonna need new tranny if i wanna run at the track. and wanna get 3.55 or 3.73 gears and 31 spline axles. all in all with dyno tune i'd like to spend no more than $10,000. i was lookin at a procharger.
:Dwell my fiances cousins husband had a 95 that would run in the mid 11's on motor. he built it himself. we will be doing the install. but im lookin at
Procharger P1SC Tuner Kit with 2 Core Intercooler
60lb Siemens/Deka Fuel Injector Set
SVT Focus Fuel Pump Assembly
SCT BA-2600 90mm Big Air MAF Meter
JMS Custom Tuned SCT X3 with 3 Custom
Programs (UNLIKE OTHER COMPANIES WHO CHARGE EXTRA FOR THE TUNES) and User Adjustable Features!
NGK TR6 Spark Plugs
kb's bap, polished head unit, afm power pipe
comes out to $5973
and 10 gatorback belts...440 dollars
lol...seriously though...Im on my 4th belt and ive had the thing a month.
I need to figure out what the hells going on here....I think im using too big of a belt becuase Ive got a brand new tensioner, yet the belts popping off and ripping.
honestly that was the first kit i was lookin at. the kit is $4999, acctualy i just lookat at the kb kit again and it does come with everything. but i think i would need a tuner so i could get it tuned.
RECOMMENDED OPTIONAL PERFORMANCE PRODUCTS (see catalog & website)
Kenne Bell BOOST-A-SPARK™ (Best Ford 4.6 ignition. Recommended after 10 psi)
Kenne Bell 90mm Meter & Chip (up to 13HP over stock meter)
Kenne Bell 70mm Throttle Body (10HP over stock)
Kenne Bell 75mm Throttle Body & "Big Tube" Kit (18HP over stock)
Kenne Bell Cool Air Kit (up to 13HP)
Kenne Bell Gauge (Boost & Fuel psi) Package
MAJOR KENNE BELL KIT COMPONENTS
Billet BIG BORE Twin Screw 2.1L Supercharger
Hi-Flo Inlet Manifolds
Billet Bypass Valve Assembly
Bar and Plate Intercooler ("Intercooled" kit only)
HD Heat Exchanger ("Intercooled" kit only)
Intercooler Pump ("Intercooled" kit only)
Water Fill Reservoir ("Intercooled" kit only)
Re-calibrated Mono Chip
36lb Injectors
BOOST-A-PUMP™
Fuel Rails ('96-'00)
160° Calibrated Thermostat
think i found a new kit:nice:
I think the 8 rib belt upgrade is around $899.00 and it will not clear the stock hood. You will need a after market hood. It is always a good idea to get a dyno tune once the install is done to to make sure AFR looks. I saw an article in 5.0 Mustangs and Superfords Magazine in October about a new kit Tork Tech that should put you right at 385-400 at about 9 pounds. It uses an 8 rib belt system as a standard.
I very, very much like this kit. You are correct....9psi will put you within the same territory as a Kenne Bell 2.1L With pulley swaps through a stock engine (with exhaust) and a forged bottom end, it made 465rwhp. They tested a modiefied Saleen (Stage II heads, cams, headers and exhaust) and with blower/crank pulley changes it made 494rwhp....on pump gas!!! :shock
Rather than regurgitate everything I've ever said about it, I'll just hot link to the thread. :D
http://forums.stangnet.com/7557374-post12.html
