looking for a set of SAFE wheel spacers?
hey therian did you use my advise on installation as follows i believe this info. is very important for safety .... you need to ensure the area behind where spacer is installed is clean and free of any foriegn material,rust ect....the spacer has to be able to mount flush. then i used some thread locker on the hub to spacer bolts and torqued them to 120 ft.lbs. then i installed wheel and torqued wheel at 100 ft lbs.and don't worry about removal of spacers after using the thread locker because i have removed my spacers to install rotors and had no problems removing. but anyway they look good...
I've always been quite cautious to monitor torque levels on the lugs...ever since my winter beater almost lost a front tire :notnice:
The spacers have been on for over two years and I haven't noticed any abnormal lug problems...spacers or wheels.
though I imagine how dirty my car looks in the pictures would make you think I have a good 1/4inch spacer of dirt in there too :D
good if they have on that long you must have a good set up tork specs ect... i try to give everyone this advise because of the posts i have read about others loosing wheels driving down the highway i have researched this subject thoroughly on this site and others and with vendors before installing mine and always try to help out with my experience...i do have scrubing issues with mine if i do not use a spacer in my rear springs... do you have this problem and/or what did you do to solve it....i'm looking for other methods because the spacer in my spring raises my rear end about 1/4-1/2 inch but they do stiffen the springs too and prevent the scrubbing....thanks.
I had to tackle a very bumpy road once and I came out of it with a cut up driver side rear tire...cuts were no more than an 1/8 in deep...so no big deal...the fender lip was depressed in one area...I rolled it using pliers when I was doing the rest of the body work and it turned out well.
I do believe it only happened due to the severety of the road and the fact that there was a sharp edge of the fender sticking out a decent amount
therian: pics much appreciated. the stance looks about right on yours. very nice :nice:
boils down to: get good brand name spacers, get hub centric, plan on spending $130 +
that about right? :)
you got it buddy...H&R or Eibachs sound like a good choice to me. I find that I have the perfect width out the back...and the stance looks excellent
