looking for advice on a carb
mustangmike6996
5 Year Member
Nov 10, 2005
483
clinton twp, MI
im building a 331 stroker. perf rpm heads with 2.02 intake valves. perf rpm intake. mild/large cam.
what CFM do you guys recommend? i have heard anything from 550-700 cfm.
also im looking at holley street avenger. how are they? i know the double pumpers were all the talk a long time ago.
i dont like edelbrock style because they are based off of a rochester quadrajet (which arent that good)
You may not like Edelbrocks because they are based on a Carter AFB, not a Q-jet, which is probably the best carb ever produced. No float bowls to leak, no metering blocks to warp and no rubber power valves to rupture. GM used them very successfully from 1966 until fuel injection came along. They are very tuneable and they even worked quite well on 1970 429 CJ's
Get a 650, mechanical secondaries if you have a manual transmission, or vacuum secondaries if you have an automatic transmission.
Agreed. Although I would like to also defend my edelbrock 1406 and say it has been more dependable and required less tuning than my old Holley ever did.
+1
What are you building the engine for? Street? Drag? Autocross? Check what carb Nascar used up to the fuel injection coming in. Holley. Not Carters. Not Q-junk. How you plan to use the car is the deciding factor of which carb to buy.
personally i very much like the edelbrock carbs. a friend of mine and is have used them almost exclusively for years now and they have all been quite reliable, even when they are on cars not used much. not so with holleys. i would use a 1406 edelbrock on your build. it is a 600 cfm carb that does quite well on a variety of combinations. so far the only engine we have used the 1406 on that hurt engine performance was on a 454 chevy making about 450hp.
I don't have any experience with the Street Avenger, but I have had good luck with the regular 4160 600 cfm w/ vacuum sec on a 302, and I have a 4150 600 double pumper on my '67 306. It screams. I would not use anything else. I have had this carb on the car for about 7 years and have never had to adjust it. I only drive the car in the summer, so even sitting 6-8 months a year hasn't been a problem. Holley all the way. I'm sure the Street Avenger would work great. 600-650 cfm.
If going with a Holley style carb, I would go with one by Quick Fuel. Out of the box one of the best carbs you can get. And for a 331 cid small block I would go with a 750 cfm carb. A 600 would leave HP on the table. It is all about getting the air/fuel right. I can make that 331 run good on a 250 cfm 1bbl. carb or make it run good on a 1100 cfm Dominator. The HP difference between the two carbs would be huge, but they would work, no bog or anything. If the air bleeds are right and it is jetted right the size does not matter. If this is a fuel economy build (and with those heads and intake it will not be) then a 600 cfm would work just as well.
Reactions: BarnStang and WTFO
I have the same motor I'm running a Demon 650dp with 3:70 gears and a t-5
i see there are a TON of Race q carb options. which one would work the best? so far im looking for 750 cfm mechanical secondaries.
the ss750 doesnt look too bad. its right about 500 bucks
Again I'd say it's more about how you're going to drive the car. My buddy's Falcon although fully licensed, working lights, full interior, etc.- it's more a race car. 8 point cage, 4000 stall, 4:10 spool, M/T slicks. His Race Q doesn't have a vacuum port or a choke horn so daily driving isn't really an option. You have to look at the full range of what features you need and how convenient you need it to be. If you want to have maximum tuning ability, stick with a Holley style carb. If you want the ultimate in part quality and precision, stick with a Quick Fuel. It's a night and day difference.
if you are going to spend the money on a speed demon, quick fuel, or other race type carb, look at one of the companies that builds carbs to suit the application. I used prosystems, ran great out of the box. Patrick was very good with customer service also. Also, as mention earlier you can call Alex, and he'll be able to pick a carb for you.
