looking for advice on a carb
  • Thread starter Thread starter mustangmike6996
  • Start date Start date Mar 8, 2012
  • 3
First Prev 2 of 3 Next Last
bartl
217
West Rutland, Vermont
Mar 13, 2012
#21
  • Mar 13, 2012
  • #21
My $.02.... if you're staying under 5,500rpm - Holley O-4777, if over 5,500rpm then move up to the O-4779. Available in plain or silver finish.
mustangmike6996
5 Year Member
Nov 10, 2005
483
clinton twp, MI
Mar 13, 2012
#22
  • Mar 13, 2012
  • #22
yea for that price im sure it went fast. i sent him a message but no response.. ill keep looking
Hack
1,945
Minneapolis
Mar 14, 2012
#23
  • Mar 14, 2012
  • #23
I would recommend you stay away from mechanical secondaries unless it's a race-only car. You will get a lot better results with a vacuum secondary carb, especially on the street. Vacuum secondary isn't necessarily slower than mechanical on the track, but it will function much better at partial throttle. The nice thing about vacuum secondary carbs is the 4 barrels only open as much as you need. This allows you to buy a slightly larger carb which won't restrict the engine at redline, but will still work great in parking lots.
Don't believe some random guy on the internet? Go to Holleys carb selector program and see what the experts at Holley recommend.
By the way, I have a Holley on my '70 and love it. Works good and I haven't touched it since I set it up. I used to have a QJet in a '76 Cutlass back in the day and that thing never worked well, even after taking it to a pro.
BarnStang
1,260
Hagerstown, MD
Mar 14, 2012
#24
  • Mar 14, 2012
  • #24
Bullitt347 said:
If going with a Holley style carb, I would go with one by Quick Fuel. Out of the box one of the best carbs you can get. And for a 331 cid small block I would go with a 750 cfm carb. A 600 would leave HP on the table. It is all about getting the air/fuel right. I can make that 331 run good on a 250 cfm 1bbl. carb or make it run good on a 1100 cfm Dominator. The HP difference between the two carbs would be huge, but they would work, no bog or anything. If the air bleeds are right and it is jetted right the size does not matter. If this is a fuel economy build (and with those heads and intake it will not be) then a 600 cfm would work just as well.
When I was still in the game, we had installed over 10 Q carbs. What a difference in tuning. Ran like a Holly, tuned up like an Edlebrock...they ALL worked great out of the box and we were buying them from Advance Autoparts cheaper than anywhere else I priced them! Great carb. Its what will be going on every one of my project cars...
65fastbackresto
1,229
AR
Mar 14, 2012
#25
  • Mar 14, 2012
  • #25
Find a used carb shop, I paid $65 for a used Holley 600 that totally blows the edelbrock 600 that i had prior to that. The shop flowbenched the carb before I got it, and he guarenteed I wouldn`t even have to adjust a float, and he was right, this thing is awesome.
mustangmike6996
5 Year Member
Nov 10, 2005
483
clinton twp, MI
Mar 14, 2012
#26
  • Mar 14, 2012
  • #26
from what everyone was saying, they all recommend mechanical secondaries for a manual trans. and vacuum for auto. i understand what you are saying, it just seems to be "a bit against the grain"
decisions decisions... lol
Hack
1,945
Minneapolis
Mar 15, 2012
#27
  • Mar 15, 2012
  • #27
That is what the recommendation used to be. Now the recommendation is typically only mechanical secondaries if the car is extremely light, the engine very powerful and very little street use. The problem with mechanical secondaries is your carb will be wrong for every situation except wide open throttle racing. Here's a link to Holley's carb selector program.
http://www.holley.com/applications/CarburetorSelector/CarbSelection.asp
I'm building a 408 Cleveland manual trans Fox Mustang and Holley recommends vacuum secondaries for me.
Bullitt347
I have been doing it wrong this whole time
4,042
3,077
204
Middle of Maine
Mar 15, 2012
#28
  • Mar 15, 2012
  • #28
The nice thing about the Quick Fuel vacuum secondary carbs is the adjustability of when the secondaries come in. This is adjustable much like an air/fuel screw. No more having to change secondary diaphragm springs ect. Just turn the screw.
mustangmike6996
5 Year Member
Nov 10, 2005
483
clinton twp, MI
Mar 16, 2012
#29
  • Mar 16, 2012
  • #29
now hearing it explained that way, it makes more sense. also as mentioned the quick fuel has adjustable secondaries which is pretty appealing.
mustangmike6996
5 Year Member
Nov 10, 2005
483
clinton twp, MI
Mar 16, 2012
#30
  • Mar 16, 2012
  • #30
the search came up with a few different carbs to choose from...
http://www.holley.com/0-83770 770 cfm $412
http://www.holley.com/0-80770 770 cfm $415
http://www.holley.com/0-80783C 650 cfm $380
http://www.holley.com/0-80508S 750 cfm $323
out of these what would be the best? the first two carbs look the best but im not completely sure yet.
mtaqua
345
#31
  • Mar 16, 2012
  • #31
Hack said:
.... except wide open throttle racing. ......
Is there any other way to drive? who cares about cruising and idle.
mustangmike6996
5 Year Member
Nov 10, 2005
483
clinton twp, MI
Mar 16, 2012
#32
  • Mar 16, 2012
  • #32
horseballz
824
Las Vegas, NV
Mar 17, 2012
#33
  • Mar 17, 2012
  • #33
Cast my vote for QFT!
http://www.summitracing.com/parts/QFT-HR-580-VS/
This is generally an updated/upgraded version of the Holley Street Avenger
http://www.summitracing.com/parts/HLY-0-80570/
Almost identical, except with 4-corner idle mixture adjustments, easily changeable idle and high speed air bleeds, easily changeable idle fuel restrictors AND externally adjustable secondaries and for only a few pennies more. A read of all the items on this page:
http://www.quickfueltechnology.com/technical-info
is extremely informative on carbs in general. I have the HR-580-VS and can't say enough good things about the carb and QFT customer support.
My $.02,
Gene
mustangmike6996
5 Year Member
Nov 10, 2005
483
clinton twp, MI
Mar 17, 2012
#34
  • Mar 17, 2012
  • #34
My $.02,
Gene
thats all some good info. i like those carbs. im researching those in 650-750ish CFM.
woodsnake
1,352
15
69
Hicksville, NY
Mar 17, 2012
#35
  • Mar 17, 2012
  • #35
My internet knowledge tells me that a slightly smaller carb, (I.E., 600 or 650 VS 750) will give better overall throttle response. You mentioned stop lights and street fun, I would stay 700 or under. Actually, my recommendation is either a 600 or 650...Preferably a Holley product.
mustangmike6996
5 Year Member
Nov 10, 2005
483
clinton twp, MI
Mar 17, 2012
#36
  • Mar 17, 2012
  • #36
this is what i have always known to be true. but ppl have been saying otherwise. i was always told that stock 302s (stock heads mild cam and intake) like 550 cfm.. since i will have pretty big heads and a large cam with a 331 i figured 700 wouldnt be *too* big
woodsnake
1,352
15
69
Hicksville, NY
Mar 18, 2012
#37
  • Mar 18, 2012
  • #37
I think ultimately, driving style will have a lot to do with how happy you are with it. Regular track visits, or mostly around town, economy, the "deal" you get on the carb, will all add in to your ultimate decision...
clement
1,104
52
59
Oak Cliff
Mar 20, 2012
#38
  • Mar 20, 2012
  • #38
my buddy and i have been trying to tune this cleveland headed stock stroke 351w shortblock. since it is a budget deal we have been trying to keep it simple. we tried 3 holleys. an 830, a 750 hp and a 650 hp. they all had a stumble. finally we got tired of screwing around with junk and pulled an AED HO modified 750 out of the box from summit. with only tuning the idle mixture screws it picked up .3 of a second in the 1/8 mile (from the cars previous best of 7.28). the difference is amazing and we havent even pulled the bowls off it yet. dont worry so much about the cfm, especially on a street type carb. its BS. the only people ive ever heard say a mech secondary carb doesnt work on a street car, havent owned a quality mechanical secondary carb.
http://www.summitracing.com/parts/AED-750HOM/
Reactions: The_Dude
The_Dude
137
Western Oregon
Mar 20, 2012
#39
  • Mar 20, 2012
  • #39
I think Holley recommends vacuum secondary carbs because they'll run better "out of the box" with less tuning. It helps to keep calls to their support line down. I have 3 different cars with mechanical secondary carbs that run flawlessly. I have a friend who is an ex-GM engineer who worked on designing carburetors and distributors. He is an expert at tuning Holleys and Demons, and dyno tested cars with both vacuum secondaries and mechanical secondaries. His test results showed that you do pickup horsepower with a properly tuned mechanical secondary carburetor.
WTFO
53
Clarks-Vegas
Mar 21, 2012
#40
  • Mar 21, 2012
  • #40
^That carb is like a more expensive QFT. For the the price of that AED, you can get a (Jeg's 793-SS-680-VSK) 650-680 cfm QF with a braided feed line, filter, and pressure gauge. Your 351w probably only needed larger squirters not another carb. I don't see how you could've gained 3 tenths by tuning your idle mix. Power is gained by adding or taking away fuel or timing or a combination of both. For the cash you guys spent on the carbs you tried, you could've tossed those Cleveland heads for some nice AFRs or ???
Do your homework mustangmike- if you go too small on cfm, you'll be leaving HP on the table. If your cam is anywhere in the .600+ lift range or your engine is built for 5500+ rpm, 750 cfm will fit the bill and can be tuned properly without stumble and instant response.
  • 3
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
R
351w stroked to 408 CARB
  • Ric4eyedFox
  • Mar 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 22, 2025
General karthief
9
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
R
1974 Datsun 620 pickup / 5.0L HO
  • RJH46
  • Aug 24, 2025
  • Other Auto Tech
Other Auto Tech Aug 24, 2025
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
