Looking for higher # injectors?
99 gt
15
Im looking to get higher # injectors, but im not sure what to go with. With the modifications that I have.
Crower cams-I went the biggest I could without having to change the springs.
4.10 gears
Port and polished the heads
Flowmaster exhaust H-pipe
Superchip programmer
The reason i am asking is because I can only run a 15.2 with those mods. I think it could be the transmisssion but i am not for sure. It has been slipping in the morning when it is cold. I ran a 15.2 with it then I had my brother run it which has a z28 that ran low 12s, and he ran the same. Anyone have any idea whats wrong? :shrug:
It only does when it is cold like sitting overnight. Reverse is fine, its only in drive that it will do it. The first time I put in gear in the norning it will just rev up like it is neutrl and not go anywhere, then I will hear a popping sound, like its popping into gearthen it will drive fine. But its only when the car has been sitting for a while. When its warm it does just fine. I bought the car used and dont know if the tranny fluid and filter has been changed ever. I have not changed them. I am changing them out tommorrow to see if that works I will get back to yall after that if it does not.
It was wrecked for a while when I got it so I have no idea anything about it before I got it. It hasnt been serviced for at least 5,000 miles thats how long I have had it. It now has dexron mercron I changed the fluid and filter today.
first off, you used the wrong fluid. it takes Mercon V, theres no exception.
I would take it to a transmission shop. Auto transmissions are pretty tricky. Just have them check it out, shouldn't cost too much unless it needs major repairs. And make DAMN sure it has Mercon V like was said.
Oh, I just remembered there is a fix called the j-mod or something. Do a search on this board.
