That's a lot of information! Thank you for putting that together. Lots of research and decisions to make!
the very first thing you need to do is sit down and make a plan on what you want from this car, and what direction you want to mod the car. then set a budget, start with what parts and labor are going to cost then triple that budget and you are good to go. once you start, stick with the plan, that way you get things done faster overall, and you dont get sidetracked with the latest whiz bang idea that sounds good but may not be for you.
Honestly, I am not sure I would tear into a fastback without thinking about it first...they are only going up in value. No one cares if you cut up a T code coupe...but it can significantly affect the value of a fastback. That being said...not sure what you mean by "fun" where you begin depends on whether you want fun in a straight line or around the corners...they aren't mutually exclusive, but it will significantly affect which modifications you do.
i agree. when you decide to modify the car, try to make sure that every modification can be fairly easily reversed by the next owner. for instance, i would avoid putting on huge fender flares(happened often in the 70s) because they are very difficult to get rid of. keep your mods to unseen areas, and bolt on changes as much as possible.
one more thing, when you start the project, focus on ONE area at a time. and start at the beginning, the chassis. you need a solid foundation to build upon, otherwise you are throwing away good money on junk.
the other thing is dont be afraid to ask questions BEFORE doing something questionable. better to ask stupid questions than make irreversible stupid mistakes. and this means asking questions here, and/or calling the experts to get good advice. for instance when you get around to the engine, and are at the point of selecting a new cam, from here you will get a ton of good choices to make, as everyone thinks their combination is right for you, whether or not it is. so call the cam manufacturers as well and get their input and recommendations for a com for your combination.
if you ask me about cam selection, i will start off telling you how to select a cam, rather than just give you a recommendation so you t least know the process, but we can save that for later.
