Looking for more HP!
  • Thread starter Thread starter tlcbpruett
  • Start date Start date Jul 28, 2006
T
tlcbpruett
  • Jul 28, 2006
Hi! I have just purchased a 93 GT Vert %.0! I am looking for any recommendations on bolt on HP! Where should I start? In info will be greatly appreciated! Thanks! Gonzo
ninety15.0
1,336
  • Jul 28, 2006
whats the condition of the car? is it stock..how many miles are on it? 5-spd or auto? Personaly i would start with gears. Best all around improvement in driveability, performance, and enjoyment!
1SLO306
My 97 GTP owns you ALL!
Mar 31, 2005
904
Muhlenberg, ky
Jul 28, 2006
  • Jul 28, 2006
gears, smog pump delete, cia, after that it gets more expensive
L
luckythirteen13
648
Anaheim, CA
Jul 29, 2006
  • Jul 29, 2006
start with gears
Venom351R
4,548
41
98
MAINE
Jul 29, 2006
  • Jul 29, 2006
Gears, Pullies. Bumping the timming is free but you will have to run a higher octane gas. Whats your budget as far as mods?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 29, 2006
  • Jul 29, 2006
On a budget? do the junkyard upgrade...
Gears - 87-88 T-Bird Turbo Coupe rear axle - disc brakes and 3.55 or 3.73 gears in one package for $125-$300. Add another $100-$200 or so to complete the brake upgrade.
94-95 Mustang GT MAF - $40-$100. It is 70 MM instead of the stock 55 MM on regular stangs built prior to 94. It uses a slip on duct on the side that goes to the throttle body and a 4 bolt flange on the other. You need a $25-$35 flange adapter from Pro-M to fit the stock slip on air ducting that goes to the air box. Wiring plugs right in with no changes. *1
95-97 Ford Explorer intake manifold & throttle body $150-$300. The intake manifold flows 220 CFM +, much better than stock. Throttle body is 65 MM, bigger than the 60 MM on stock stangs. I got a 96 with EGR passages that match the stock setup, so my smog gear works just like factory. You’ll need a 65 MM EGR spacer & new gaskets for $65-$90 so you have a place to mount the EGR & throttle linkage.
3G alternator from 94-95 Mustangs or other Ford. $20-$120. A must have to make the electrical system work like it should. You’ll need a 4 gauge power wire and a 125-135 amp fuse to go with it about $15- $30.
Lincoln MK VIII electric fan -$40-$160. Free up some HP by not having to drive the stock fan. The 3G alternator upgrade is a must have prerequisite before you do the MK VIII fan. You won’t have enough electrical power if you don’t do the 3G upgrade.
Aluminum driveshaft: (courtesy of shawn13) It needs to be from a 92-93-94 Aerostar AWD and you will need the u-joint, part #353 from NAPA. It should bolt right up after the u-joint swap.
*1.) I got a metal flange adapter from Powered by Ford for $35 and tax. That was over a year ago. Summit Racing may also have one too.
Powered By Ford
1516 South Division Avenue
Orlando, FL 32805
Hours 0800-1800
Phone 407-843-3673
http://www.poweredbyford.com/
stang730
56
Long Island N.Y.
Jul 30, 2006
  • Jul 30, 2006
Gears and exhaust to start IMHO. Then you could consider some Heads, Cam, and Intake.
foxbody88stang
21
COLUMBUS,OH
Jul 30, 2006
  • Jul 30, 2006
Start with h pipe,catback then go for gear ,heads ,exe.
MustangGT92
89
Oklahoma City
Jul 30, 2006
  • Jul 30, 2006
all sounds good...an easy bolt on though is underdrive pulleys...and cold air.....then start saving money....even roller rockers...those are not hard to put in...maybe a spacer for the intake....
smokenda22s
20
#10
  • Jul 30, 2006
  • #10
on a vert you want to do subframe connectors, even though its not a performance upgrade, its an upgrade that is needed.
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Jul 30, 2006
#11
  • Jul 30, 2006
  • #11
http://forums.stangnet.com/showthread.php?t=636360&showpost#3
Synned
took tubgirl on a date and got banned
Mar 31, 2005
991
Philly
Jul 30, 2006
#12
  • Jul 30, 2006
  • #12
Did you guys feel a difference after a CAI?
I haven't gotten one just because I thought it would be worthless...
For 30 bucks I'd grab one..
srothfuss
Oct 17, 2004
1,796
Woodward Ave.
Jul 30, 2006
#13
  • Jul 30, 2006
  • #13
I don't believe in them, but some think they add some power. (Of course, we are not talking about an Andersone Power Pipe either)
Brakes Front Brake Hardline Routing
  • 93Nifty
  • Sep 11, 2026
Fox 5.0 Mustang Tech Oct 11, 2026
limp
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
Engine Are These rings OK?
  • PonyGTrider
  • Sep 21, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
PonyGTrider
Front window issues
  • bruno
  • Nov 7, 2026
Fox 5.0 Mustang Tech Tuesday at 10:26 PM
AeroCoupe
