looking for video or audio clip of e303,or f303 cam?
5.0_sleeper
47
Could somebody post some links of a E303 cam or a F303 with/with out 1.7 rr.
Curious what each sounds like, gonna purchase one of the other someday. Either video or audio clip.
These are two of my clips. Not the best sound, but it works.
well, other clip is taking too long.
I like the fact that they are ground on the same base circle as the stock cam. No need to run around finding different length pushrods.
The ramp rate on the Ford cams is not as aggresive as some other cams so it's easier on the springs,lifters and valvetrain. You are less likely to run into problems such as coil bind, valve float and other related valve train issues.
It just seems to take less work to install one.
I selected the F cam because it I plan on adding a turbo in the future and is regarded as the best off the shelf turbo cam on turbomustangs.com
Some guy there made 1200 hp with a 302 turbo and an F cam.
As far as motorsport cams being old, so are some of the COMP cams, Crower 15510, 15511, 15512, Crane 2030, 2031, 2040, Steeda 18 and 19 and other cams commonly used in 5.0s. No one seems to point those out? Yet some of these are older than the F cam.
