Looking into Adjustable Struts
  • Thread starter Thread starter Obsol3te
  • Start date Start date Jul 22, 2005
Obsol3te
106
Jul 22, 2005
  • Jul 22, 2005
Any moderatly priced adjustable struts that could be changed to coil overs later down the line?
Or brands I should just stay away from?
ss93cobra
1,422
Wilmington NC
Jul 22, 2005
  • Jul 22, 2005
KYB adjustables are probably going to be the best priced, unless you can find a deal on Koni reds like I did. Not sure of the change to coil over though....
Rick 91GT
Mustang Master
95
99
PA
Jul 22, 2005
  • Jul 22, 2005
Go with the new STRANGE adjustables, very nice pieces around $115 each JEGS carries them...converting to a coil over is easy
Obsol3te
106
Jul 22, 2005
  • Jul 22, 2005
These Strange 10Ways?
Just making sure.
None of the speed shops around here seem to keep any instock. And none of them carry strange struts.
So Summit is my only way
Edit: Put in an order for em anyways. Hope this cures my problem...
Rick 91GT
Mustang Master
95
99
PA
Jul 22, 2005
  • Jul 22, 2005
Yep, Summit use to not carry them but I guess they started.
Not sure where you are located but if you are in MI, Team Z Motorsports or Skinny Kid Racecars may also be able to help you.
Obsol3te
106
Jul 22, 2005
  • Jul 22, 2005
Nowhere close, live up in NH.
Thanks for the replies though.
Been having a rubbing problem, current struts are shot after a QA1 K-Member install.
Plopped in some polyurethane spring isolators to try and fix the problem along with CC plates.
It sort of helped, but during the installation process noticed the struts were basically gone.
So it's still basically riding on the fender.
(car's lowered 1.5" to boot)
Boostin
57
  • Jul 22, 2005
Go with Bilstien race valved. they are the best, or tokico illuminas. www.maximummotorsports.com has them
trents99
438
Hampton, GA
Jul 23, 2005
  • Jul 23, 2005
Check out http://www.stangsuspension.com/store/shockcat.asp
I've used them and saved quite a bit in the past.
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
3K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
Suspension UPR Coilover sleeve dosent drop down over strut
  • Creomod
  • May 25, 2025
Fox 5.0 Mustang Tech May 28, 2025
RaggedGT
Brakes Front Brake Hardline Routing
  • 93Nifty
  • Sep 11, 2026
Fox 5.0 Mustang Tech Oct 11, 2026
limp
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
