four.six
todd4566 said:Anyone looking for a tremec MGW?![]()
i will buy it from u.. is it for tremec 3650?? if so, send me a PM.
ronaldriske said:I'm using the stock handle and isolator with the steeda tri-ax. Works great for comfort and is silent as stock. It is not as short or as precise as with the tri-ax handle, but it is a vast improvement over stock.
I'm confused as well. I thought the stockers had different bolt sizes that prevented this...todd4566 said:How did you make the stock handle work? I was just online thinking about using a Tri-Ax again, but I don't remember the bolts from the stock handle matching up with the Tri-Ax.![]()
Here is mine:todd4566 said:The Hurst isn't bad, but from what I'm seeing the Tri-Ax on the highest setting is probably the closest thing in the market to factory height. I would consider a Hurst with the chrome stick and retro white shift ball, but the Mach has a silver theme going on in the interior and I don't want to spoil it.
Spreadman said:If you don't like the MGW based on effort and handle height, then get a Pro 5.0 and use the stock handle. You will need to call Pro 5.0 and get their spacers for the stock handle. You can't reuse the rubber isolators, however, go to Home Depot and get some rubber washers, put them between the handle and the shifter, it will act like the rubber isolator. I've done it, it's not bad. I just hated the rubbery feeling and tall handle.
when i installed the MGW on my 3650 i stuck it in gear, installed the stops, and then backed them off a few threads and made sure the jam nut was good n tight so it didnt go traveling on me.todd4566 said:*When I called Pro5.0, I inquired if removing the shift stops was an option for Tremec 3650 applications - the guy said it's a common misconception that the Tremec won't benefit from shifter stops & that the Tremec does have internal stops buy not for the shift forks. I always figured having shifter stops set a few turns back from the gear engagement point could be beneficial, but what's the deal? So many people on here and other forums have removed the stops, but who's correct? The Pro5.0 guy made it sound like the 3650 needs the stops just as bad as the T5/T45's.![]()
todd4566 said:I'm thinking about doing that.. it's a debate between going with the Tri-Ax again, using a Pro5.0 (never used that one), or just rolling stock.
So now I have both. With my UPR pistol grip the Red was too high IMO but the blue is just about perfect. Also with some driving they do become less effort.helty said:hey todd, i know you said the MGW isnt for you, and thats all gravy, just wanted to see if maybe this was an option for you? would give you better reach than the orange handle, and the added leverage may make the shifts a little easier. just throwing it out there for you.
http://www.mgwltd.com/mustang_shift_handle.html
I took the stops out like it said in the directions. Should i put them in and leave them out a couple of turns. I havnt had any problems yet but dont want to break anything. What do you think?git-it-83 said:I'm using stops on my TR3650, but I have them back a bit farther than recommended, to avoid any mishaps. I have heard of it having the internal stops, but consider the shifter's stops as a backup if the internals get worn or fail.
cobra2798 said:I took the stops out like it said in the directions. Should i put them in and leave them out a couple of turns. I havnt had any problems yet but dont want to break anything. What do you think?
