loose windows
  • Thread starter Thread starter Asgard
  • Start date Start date Dec 14, 2003
First Prev 2 of 2
ECU5.0
Banned
Jan 10, 2004
1,803
raleigh, nc
Jan 25, 2004
#21
  • Jan 25, 2004
  • #21
yeah, mine rattle...but yall cant top the horrible screaching noise my driver side window makes when it is rolled up....kinda like the most annoying noise in the world from dumb and dumber.
F
fost9508
131
#22
  • May 1, 2005
  • #22
Do we have the pics for this yet. I also have a loose passenger window. Not sure if it is the same problem. My seems to be loose in front...but there isn't a lot of room to see or work...without drilling out rivets.
Thanks
I
iwashmycar
20+ Year Stangneter
Apr 7, 2004
1,236
Columbus, Ohio
May 1, 2005
#23
  • May 1, 2005
  • #23
mine rattle like crazy too sounds like im gonna shatter the window when i close the door with the windows down...My driver side also has a 'dive' in the window as it goes up....
-adam
85_SS_302_Coupe
6,945
1,598
223
Northern KY
May 1, 2005
#24
  • May 1, 2005
  • #24
Maybe the dew wipes? If they're wore out then they're not as snug against the window as they used to be. It wouldnt surprise me if the windows rattled after a few months when they were new.
W
WhiteHeat306
283
Philadelphia Suburbs
May 1, 2005
#25
  • May 1, 2005
  • #25
mine barely touch the window anymore. that's probably one of the causes.
hemi_fan
279
Ontario, Canada
Jul 29, 2012
#26
  • Jul 29, 2012
  • #26
dcormier said:
Alright, I have an update on this. Today a friend and I replaced the window bushings (from 50resto.com) for the passenger door to try handling the rattle in that window. Man, was it a royal pain.
The bushings themselves are quite small. About 1" square. They go around the guide rail for the window. You do have to get the guide rail out for this to work, and that's no easy task.
I will get pictures next week when we do the driver's window (which rattles much more), but in the mean time I have a couple of tips:
1) Pop the existing bushings out of their holes before attempting to remove the guide rail. This will give you a degree or two of extra play in the rail which will be very helpful. The rail can be removed without doing this. But as we discovered, it's not easy at all. The rail itself has a bolt at the top of the door and on the bottom of the door.
2) Once you've gotten the existing bushings out of their resting places go ahead and lower the window to the bottom (carefully, since it will now have more wobble to it). Getting the guide out will take some work. How we did it was to have one person pull on the part of the door where the guide bolted on to the top (there's a lot of flex in that piece of metal) so we could get the top of the bar out of it's position. We moved the top of the bar away from the hinges on the door.
One thing you need to be very aware of at this point is that the piece of metal at the top of the bar has some very sharp corners on it. It works pretty well for someone to keep their fingers between this piece and the window, especially if they're tinted. We discovered this the hard way and I now have a nice 2.5-3" scratch in the tint. Even letting this piece bump the tint leaves a pinhole in it. The tint was old and needed replacing, anyway. The other window has some bad scratches in the tint already, so now they match.
Anyway, you'll kind of have to fight with the bar to get it out of there, but it's doable. I promise.
If you removed the bushings before removing the bar, they're probably in the bottom of the door right now. Remember to grab these and toss them so they don't rattle.
3) Once the bar is out of the way, I would suggest (with the window all the way down) pushing the window as far away from the door hinge as you can. This will make it so you have get the lift arm out of it's guide. Once you've done this, clean out that guide rail with a Q-Tip and raise the arm so you can clean off the plastic piece at the end, too. We thought it was a good idea to roatate that end piece and put it back with the two previously unused sides at the top and bottom since they wouldn't be at all warn.
4) Go ahead and get the lift arm back in it's guide. Be sure it's in there in such a way as to use the "new" sides, not the old.
5) What we did when we put the new bushings in was to put the lower one in place, and put the other on on the bar (so we would have that extra play while we were putting the bar back to make it less of a pain, but could still get the bushing on).
6) Now for the really fun part: getting the bar back in it's place. We had one person slide the bar into place and another watching and guiding it (you'll probably hit the guide for the lift arm once you get the bar into the space where the top bushing goes, otherwise. That's what happened to us). Once you get it into the carige for the window, get it into the hole in the bottom and then allign it witht he top. Again, I cannot stress how easilly the piece at the top end of the bar can mess up window tint as well as the glass. Be very careful when working with this piece.
7) Once you get the bar into place, put the bolts on the top and bottom rather loosely. The top hole for the bar has some play so you can adjust the alignment. Get it tight enough so the bar can move some. Raise the window to the top so you can lubricate the bar and the guide for the lift arm.
Assuming nothing else is wrong, you should now have a window that goes up and down smoothly and doesn't rattle! Enjoy.
I'm trying to do this. Does anyone have more information on how to remove the bar? Which way did you pull it out, it seems really tight in there and I don't want to try to force it one way and break something. He says he pushed it away from the hinges, does that mean he rotated the bar 90 degrees so it was away from the hinges and then lifted it? I assume he took it out while still in the door as there appears to be no way in hell it will fit out the opening where the glass comes through unless I remove the glass.
7991LXnSHO
wanna catch the space herp
7,387
2,746
194
Kearney, NE
Jul 30, 2012
#27
  • Jul 30, 2012
  • #27
I am so glad you posted this. My power windows rock back and forth when part way up or down. I am picky enough to think it did not come this way new. A while back I posted a question, and until now, no one had a real clue. At least I know what I am in for. I already had the bushings. I anxiously await the pictures to see if my bushings are missing and where they go! The top metal square plate that slides over the rod seems to be loose and I do not know if this is the problem.
Anyone with glass shop experience have an easier procedure? I am wondering if we can pull the glass first to protect the tint and glass?
hemi_fan
279
Ontario, Canada
Jul 31, 2012
#28
  • Jul 31, 2012
  • #28
To get the glass out you just have to drill 2 rivets. It really isn't that big of a job to remove it although I'd prefer not to if I don't have to. I'm going to work on the car this evening so hopefully someone can tell me how they wriggled that bar out or I'll have to do trial and error.
ID89GT
1,659
18
49
Spokane Valley, WA
Jul 31, 2012
#29
  • Jul 31, 2012
  • #29
Haha my window on the drivers side of my 85 is way loose. Like.. when you roll it up you can almost pivot it around. I have to hold it so it goes up straight just to be able to roll it up all the way. I haven't pulled the door panel off yet but I am guessing one of the rivets that hold the window in broke or something. Its a t-top too if that makes any difference.
First Prev 2 of 2
Cooling Jacket Pitting Idea's?
  • BoostedRed89gt
  • Aug 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Mustang5L5
Help with window and possible engine
  • StefRena22
  • Jun 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2025
Willybill32
Still need an Alignment?
  • from6to8
  • Jun 1, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jun 2, 2025
AeroCoupe
Can makes noises when driving poping
  • Creomod
  • Oct 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2025
Creomod
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
