Loss of Power
kpack5982
Yeah, it was pretty stiff, but eventually a buddy
Jul 13, 2005
325
Granger, IA
So the car is running fine with the iac all cleaned, tps is running the right volts and i have a brand new, clean maf. Problem is when I gun it i notice that about 3500 rpm it seems to bog down, less acceleration. Can't really notice in first cause it winds up so fast with the 373s but definitely in 2nd and 3rd. Any ideas what I could do, or is that just where the limitation of the stock intake is, I thought it was higher up than that, but I dunno? HELP?!?!?
Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
I thought the check engine light had to be on in order to pull codes........learn something everyday. I had a car do that to once, ended up being a fueling problem, or lack of sufficient fuel pressure.
