  • SN95 4.6L Mustang Tech
losse coolant
  • Thread starter Thread starter Killa
  • Start date Start date Jul 9, 2007
Killa
1,006
56
49
Jul 9, 2007
  • Jul 9, 2007
I own a 1998 mustang GT manual with 136k miles. When I bought it, radiator is crack, so I replace it, ( my mechanic replace a automotive radiator, not a manual readiator . you guy think that cause the problem ? ) 2 week later I found coolant is leak out of my thermostat bolt, so I went and bought a new T-Stat and 0-ring. when I install it, I found out that my old t-stat dint have an 0-ring, is the 0-ring support on top of the t-stat or under the t-stat ? after install I add more coolant, runing to normal temperture, take it for a ride, then went home, I saw alot coolant leak out near the coolant cap, you guy think my cap is cause coolant to loose or any thing cause my coolant to loose ? my car temperture now is not point to the mid temperture any more, its point very closer to the middle, what happent ? thanks
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Jul 9, 2007
  • Jul 9, 2007
the coolant crossover on the intake manifold has cracked and the whole intake manifold needs to be replaced with the updated model with an aluminum crossover. there should be an o-ring on the thermostat, the part number is F1VY-8255-BA if i remember offhand, its been a long day. the updated manifold kit from Ford will have an o-ring in it. from the sounds of it, you also did not properly fill the cooling system. it must be burped to allow all of the air pockets to escape.
an automatic radiator is fine in a manual car. i have one in my car with no ill effects on cooling.
Killa
1,006
56
49
Jul 10, 2007
  • Jul 10, 2007
I read some where that, problem is a recall right ? what can I find out that my cross over is crack ? I should saw the leak ?
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Jul 10, 2007
  • Jul 10, 2007
the leak is very hard to see with the naked eye. it usually happens where the alternator bracket bolts to the crossover.
technically there isn't a recall, just a legal settlement. Ford no longer honors it, as the proper time to file has expired.
I'm guessing English isn't your first language. If it isn't, keep trying, you're getting better. If it is, well, its very hard to understand.
Killa
1,006
56
49
Jul 10, 2007
  • Jul 10, 2007
yes english is my second language . Do you know how much for new intake manifold and labor ? thanks
Oil cooler delete 4v 4.6 1999 cobra mustang
  • sami12
  • Feb 24, 2026
SN95 4.6L Mustang Tech Feb 25, 2026
GOvert
G
K
86 GT Water Pump
  • Kade5114
  • May 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2026
nickyb
J
2001 coolant issue
  • jr273
  • Jan 24, 2026
  • The Welcome Wagon
The Welcome Wagon Jan 24, 2026
L
Car has been overheating. Not sure what is causing it. Any help would be appreciated.
  • Luckysgirl
  • Jun 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
Luckysgirl
L
R
coolant
  • Rudy10thsvt
  • Sep 28, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 1, 2025
General karthief
