Lost 3ths with VRS Catted X Pipe!!
rcn4him
153
Milwaukee
Bought a used one for $120 and thought I'd throw it on. Really like the sound
but it sure seemed to soften up the powerband. Anyway I took my car to the track twice in the last 2 weeks and made about 6 passes each time with a little variance in weather and here's what I found:
2:10 60ft - 14:00 to 14:10 at over 99mph without
2:20 60ft - 14:30 to 14:40 at over 98mph with
Same driving syle, no other changes :shrug:
From what I understand, 1/10th at 60ft equals 2/10ths at the end of the track. So there is 2/3 that you lost. Weather, shift points, etc. could have changed slightly and caused the other tenth to be lost :shrug:
Check for leaks, make sure its bolted on tight. Theres no way you should lose power by bolting on a mandrel bent, free flowing 2.5" X-pipe over the stock 2.25" pipe with restrictive cats....you should be picking up about 9rwhp...weather can play a huge role, and if you have a leak or a loose bolt it could be killing your performance.
No Leaks!
The weather has been very similar in temp and humidity!
What about the MPH?
