Loud awful sound
Pspangler37
New here
Little about the car
It's a fresh 306 stroker ,with afr 165 heads,port match for heads cobra intake ,f 303 cam ,BBK long tube headers , BBK 75 mm throttle body ,24# injectors ,75 mm /24# match pro m maf, aode transmission with 2800 stall
Haven't drove it yet except around the block had alot of horrible wiring splicing issues from previous owner the stock motor that came with the car I took out for the 306
Okay here's the issue when cold start the car run fine no noise rpms about 980ish sounds awesome but when it gets in operating temperatures about 165ish there's this awful whistle sound and rpms go's up about 1150ish but it only does it in park and neutral. When in gear the noise goes away and rpm goes back to down to 9 something. Back in park the awful loud squeal/whistle sound is back.. if any one can help out would be greatly appreciated!
Thanks Paul
I did and correct the prior codes only code I got is for the o2 sensors due to not hooking them up yet.. for leaks I'll double check them but it does sound like it's coming from the back of motor near transmission
