loud "clunk" noise, help please
  • Thread starter Thread starter 19Nathen66
  • Start date Start date Apr 30, 2006
First Prev 2 of 2
ozstang65
313
Queensland, Australia
May 13, 2006
#21
  • May 13, 2006
  • #21
jerry S said:
As a licensed attorney at law acting on behalf of Mustangs Plus, I hereby order you to cease and desist from the unauthorized use of the registered mark "restomod" without first having obtained permission from its creator and owner, Ron Bramlet.
Just call it 'Retro-Tech' then!
19Nathen66 said:
. When i very first heard the noise my initial thought was that it was slammin my gears since it would happen around 10 mph....any more suggestions or insight would help. thanks
...Probably the power valve responsible for first gear then.
latamud
791
Tampa, FL
May 13, 2006
#22
  • May 13, 2006
  • #22
Restomod.
M
MitchGT
204
May 14, 2006
#23
  • May 14, 2006
  • #23
Does it shift too hard on acceleration ? if the vacuum modulater on the tranny isn't connected or working it might be downshifting too hard. Probably not the issue, but it's not real hard to check.
19Nathen66
26
#24
  • May 14, 2006
  • #24
No, on acceleration it doesnt shift to hard. How would i check for that tho, since its easy?
T
Timothyeg
51
Sayre pa
Aug 23, 2020
#25
  • Aug 23, 2020
  • #25
1320stang said:
Strut rod bushing gone?? If its the front, that would rule out the drive shaft as the front u-joint is about even with your hip. BTW, you didn't mention if it was a C4 or a manual tranny. Also, usually, a bad u-joint has a sort of ring to it when it clunks.
I actually agree.
First Prev 2 of 2
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
Electrical Innovate PSB-1 is DOA? Am I an idiot? All plausable. Please Help
  • Dontknowchit
  • Apr 26, 2025
Fox 5.0 Mustang Tech Apr 26, 2025
Dontknowchit
Dangerous High RPM at stop/ RPM Jump when switching to Neutral then dies.
  • 02torchvert
  • Dec 17, 2023
SN95 4.6L Mustang Tech Jan 3, 2024
Yel2002GTAuto
Y
Please Help!! 2000 Mustang Theft Light, car won't start issue...
  • 2000Mustangguy
  • Apr 13, 2023
6K
1996 - 2004 SN95 Mustang -General/Talk- Nov 8, 2023
Squaretundra
Please Help! 2000 Mustang Convertible V6 Theft System Issue, Car Shut off, Now no, Start, Theft Light Flashing quickly!
  • 2000Mustangguy
  • Apr 13, 2023
3K
1996 - 2004 SN95 Mustang -General/Talk- Apr 24, 2023
90sickfox
