Loud Tick-cold Idle..
Alex Kraczek
40
Freshly rebuilt 5.0, have a pretty serious tick on cold startup (driver side particularly) only sometimes. Other times it is quiet.
Thinking it is a lifter bleeding down after sitting, sometimes it does it sometimes it does not. Goes away after approximately 2 minutes of idling.
Input? Should I be worried?
Thanks
A friend of mine broke the pedestal hats on a couple of my roller rockers, so Im currently using the my stamped stock rockers. I did not check valve lash, I tightened down rocker arms and made sure the pushrods didnt move up or down, thats it. Car sounds perfect when warmed up, but even if I turn it off to get gas or something and start it, it will tick tick away for a couple minutes then slowly fade.
Bleeding down? Should I be concerned? Really dont wanna tear it down again. It is not an exhaust leak, I verified. Coming from driver side, approximately the 5th cylinder I believe.
Take a 4' section of garden hose or heater hose. Stick one end in your ear and move the other around to suspected noise sources. Works exactly like a stethoscope and helps you pinpoint noise sources.
