SOLVED - See solution at post #27
Hey guys I an 86 GT Vert. I,m trying to figure the best way to connect the Low Brake Fluid wires to the Cobra Master Cylinder setup.
I have not found a thread, on any site, that talks about connecting the low brake fluid sensor wires from the 4 eyed cars to the popular 93 Cobra, 87-93, and SN95 Brake Master Cylinders.
How can I make my low brake fluid senor in the dash work after doing the 5 lug conversion? I am using the 93 Cobra M/C. I can use the SN95 V6 unit but prefer the Cobra 1" bore.
It seems that some have 2 wires and other years have 3 wires....
I pulled a donor wiring harness connector for SN95 from the bone yard.... Not sure if it will work on the Cobra Reservoir....?
Thanks.
Thanks.
