Low compression
  • Thread starter Thread starter MUSTANGJOE
  • Start date Start date May 27, 2005
MUSTANGJOE
Silver Stanger
1,644
17
59
May 27, 2005
  • May 27, 2005
Hey guys ..
just did a compression test this week. My lowest # was 115 psi and the highest was 125psi. My engine has 79 000 miles. What can cause this low score?..should I rebuild or not? Thanks
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
May 27, 2005
  • May 27, 2005
Depends on what you are looking to do.
If you add a Charger without a tune, you will surely chew up that motor in no time. But if you are just planning on adding new heads, cam, etc... You should be OK if your car doesn't see track useage and you take care of it.
But, if you got the money... Might as well do things right the first time and get them over with.
maverick0716
3,924
Chilliwack, BC, Canada
May 27, 2005
  • May 27, 2005
Could be worn rings or something like that. Those miles are fairly low, but they could have been hard miles.
J
jerry beach
2,671
Ocala,FL
May 27, 2005
  • May 27, 2005
Did you have the throttle plate wired wide open when you ran the test? Was the engine warm? Did you have all the plugs out when you spun it?
You can put a few ounces of oil in each cylinder and do the test again. If the #'s come up alot, then that points to bad compression rings. If you read the directions and did it properly, then fine. If not you should do the dry test over.
D
Daggar
3,902
  • May 27, 2005
MUSTANGJOE said:
Hey guys ..
There's nothing wrong with it the way that it is. All of your cylinders are within 10%. The Ford shop manual shows a maximum difference of 25% between the highest and lowest cylinders to be acceptable. I'd say that you're WELL within that range. That motor will likely run for another 100,000 miles.
BornInAFord
199
Bend, OR 97701
May 27, 2005
  • May 27, 2005
Sounds ok, and like Daggar said, the most important thing is the consistency. Do you have the stock cam? An aftermarket cam often will change the dynamic compression, so your test can't be compared to other tests. In fact, often the higher perfomance cams will have even less cranking compression than the lower performance ones. Reason? Most cams have some overlap, and most aftermarket performance cams will have more overlap so they can use it to better fill the cylinder at higher RPMs. This means that at cranking speeds (400-800RPMs?), both the exhaust and intake will be slightly open at TDC.
Daniel
HISSIN50
34
129
May 27, 2005
  • May 27, 2005
Well said, and what came to mind to me. Trying to compare (or look at compression numbers absolutely) is hard - too many variances in testing methods. and doing a wet test after the dry (like Jerry said) reveals a lot more info.
good luck.
MUSTANGJOE
Silver Stanger
1,644
17
59
May 28, 2005
  • May 28, 2005
The motor was cold when they did the compression test. I dont know if all the plugs were in or out.
HISSIN50
34
129
May 28, 2005
  • May 28, 2005
if you have forged slugs, the fact that the motor was cold can matter (numbers can be down on a cold motor with forged slugs).
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
D
Engine Questions on compression test results
  • dqureshi06
  • Jan 6, 2025
Fox 5.0 Mustang Tech Jan 7, 2025
03 Mustang, found dinged pistons, pics.
  • 2003 mustang gt modded
  • Aug 8, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 19, 2025
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
T
Fuel P0193 on a 2003 3.8 v6
  • Treemaster5000
  • Aug 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 18, 2026
Treemaster5000
T
