UDTBadkarma said:
Not to doubt what you're saying. But i thought that oil in the compression test ("wet compression testing") determines that the PISTON RINGS are not sealing properly, and its the piston rings that need replacing. How does this test tell u the coil is bad??
yeah thats exactly what I am testing for this way the piston rings....the coil and plug you test for in other ways. a serious misfire can wash the oil coating off the rings and cause a compression drop. when you drop abit of oil down there this will reseal the rings, if you then swap the coila nd plug on that cylinder you will find the ring will stay sealed because it is no longer "washed down" reread my first post and you will see this is what I am talking about.. a ring washed down.
So to sum it up.. this is what happens
1. coil/plug goes bad and eninge misfires
2. as you drive around like this unburned fuel leaks past the rings into the oil pan and causes the rings to loose it's oil coating. the rings without the oil coat do not seal as well
3. tech goes in even if he fixes the ignition problem the cylinder will still misfire because of the low compression caused by poor ring seal
4. tech does not understand the concept of unburned fuel washing the rings down and runs a compression test and sees a 20-40 percent drop in compression on that cylinder.. so he assumes it needs a motor..
All it really needed was a little bit of oil to reseal the rings and the ignition problem fixed and oil changed. after this it would run properly and the rings will stay sealed.
The rings were never damaged, they just can not seal properly when this happens, as soon as the misfire is fixed and oil gets on the rings the compression will come back.
sometimes a simple problem can cause another simple problem, and this can confuse the tech if he has not seen it before. in this case a ignition failure causes a low compression condition.
many techs make this mistake.. I learned this myself years ago when I got burned on a crown vic 4.6.. I sent a perfectly good motor back to ford
