  • 1994 - 1995 Specific Tech
"low coolant" light problem
  • Thread starter Thread starter 95riosnake
  • Start date Start date Apr 30, 2005
95riosnake
630
Pittsburgh, PA
Apr 30, 2005
  • Apr 30, 2005
Lately when my car has sat for a while (like 8 hours or more), the "low coolant" light will come on when I start the car and will stay on till the car is shut off. I'll drive the car 10 minutes to where I am going, then 5 minutes later when I go to leave, I'll start the car up and there will be no "low coolant" light...
What could be causing this? The temp gauge isn't above normal operating temp, and the radiator overflow shows my coolant at the right level...
Any help is appreciated
StL3GTJLH
20
  • Apr 30, 2005
what about your actual radiator, is it full? I was having a similar problem and it ended up being the bypass hose and one other hose right next to it were leaking, i replaced them and now no problems!
95riosnake
630
Pittsburgh, PA
Apr 30, 2005
  • Apr 30, 2005
I'll give that a try...thanks
HISSIN50
34
129
Apr 30, 2005
  • Apr 30, 2005
if the level is alright, pull the sensor out of the overflow bottle and clean it. most of them that have never been cleaned are filthy.
good luck.
M
MadHandle8169
432
Brick, NJ
Apr 30, 2005
  • Apr 30, 2005
Are you supposed to fill the reservoir completely up because there is a black magic marker line drawn in the middle of mine.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Apr 30, 2005
  • Apr 30, 2005
No, it's not supposed to be 100% full. There are two lines on the bottle (raised lines on the plastic. One is warm, one is cold.
I would try this. Remove the overflow bottle cap and pull the sensor out of the bottle. Clean the connectors and take a piece of bare wire and short out the two tabs. The coolant light should turn off if you start the car. If it doesn't, you have a wiring problem at the sensor. All it does is run current into one wire, and if the water is there, it will pass the current through the other tab. Nothing fancy.
Scott
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Apr 30, 2005
  • Apr 30, 2005
Scott
i had the same problems, cleaned the little metal prong looking things and no more problem
95riosnake
630
Pittsburgh, PA
Apr 30, 2005
  • Apr 30, 2005
Scott
Cool, I'll give that a shot once it stops raining outside so I can pop the hood lol. I can't wait to go home and have a garage again!
95riosnake
630
Pittsburgh, PA
May 1, 2005
  • May 1, 2005
did it today and worked like a charm! thanks guys
94Silverbullet
488
MD
May 1, 2005
#10
  • May 1, 2005
  • #10
when this happened to mine, all I did was added antifreeze to the cold line before I started the car and the problem went away.
T
tderrick
312
May 2, 2005
#11
  • May 2, 2005
  • #11
This seemed to happen to all of us at about the same time. After 10 years or so, the contacts on the sensor just got corroded.
95riosnake
630
Pittsburgh, PA
May 2, 2005
#12
  • May 2, 2005
  • #12
yea, there was a bunch of black nasty sh** all over the contacts
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
R
coolant
  • Rudy10thsvt
  • Sep 28, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 1, 2025
General karthief
Fox Help
  • 93fox85
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 23, 2026
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
