Low Coolant Light
that light is driven from the recovery tank....you must have a small leak...specially in the cold weather, these radiators tend to leak some....I know mines been doing it for years....Im mindful of it and keep tabs on the recovery tank...
Remove the cap and tube from the overflow bottle. There are two contacts at the bottom of the tube. Clean them off with some rough sandpaper, or a scraper of some sort. Once they are clean, reinstall & check to see if the light is still on.
Remember, you need to shut off the motor and restart it to verify that the light is still on or off.
Scott
It was corroded contacts indeed!
Just unplugged the sensor at the cap and took the cap off. The sensor probe
comes out with the cap as an assembly. Cleaned the contacts with some emory
cloth- bod-a-bing! No more Low Coolant light.
thanks for the help...
