Low Coolant Problem?
Mirage775
10
Alabama
Hi, I'm new to the forums. Anyway, I bought an all original 1993 GT:nice: last night and as soon as I started it up, the "low coolant" light came on. Now, the guy I bought it from said it was washer fluid, but I knew better. I got home, added about half a gallon of anti-freeze in it and thought the light would've gone off, wrong, it's still on. Does anyone know what could be the problem, sensor maybe? It's not running hot, at least it didn't on the way home last night. But, if like I said, if anyone thinks they have a clue what it is, would you please let me know?
On another note, the drivers' side door won't lock with either the key or power lock switch. Is there another area of these forums I should post this? Thanks, Jason
The low coolant sensor is attached to the stock filler neck for the coolant overflow tank. Disconnect it and the light should go out.
The next step is to check the coolant for oil and the oil for coolant. If the oil has a milky crud in it the coolant is leaking it the oil. This is very bad news, the coolant can damage the bearings. The most common source of coolant in the oil is a blown head gasket or an intake manifold gasket leak.
If you continue to loose coolant, I would recommend that you rent/borrow a coolant pressure tester from your local auto parts store. The coolant pressure tester puts air pressure in the cooling system. The pump enables you to put 12-14 PSI pressure in and watch for external leaks.
Thanks, I drove it yesterday for about 50-70 miles and it ran great. When I got home, it was too late/cold too mess with it. I will check it this afternoon when I get home and from what I gathered from you, if the coolant is already low again, don't drive it, until I found out what's wrong with it? I have a friend who's a great mechanic, I may just stop by today and ask him about it and see what he says. I'm pretty mechanically inclined and I've replaced gaskets in the past on other venicles, but I'm pretty new to the 5.0 Well, gotta get to work, thanks for the help.
OK, I checked out the coolant level yesterday and it was about a gallon low this time, but when I checked the oil, it didn't look milky-like, it looked sorta brownish/black, like it needed changing. I also talked to my pops' mechanic buddy today and he said it's probably the heater core or water pump, so let's hope it's one of those.... :shrug:
If it was a heater core you would have a damp passanger floor. Water pump you should be able to see by just looking at it. Its on the front on the engine behind the fan. Dried coolant looks chalky and white. You would also be able to smell it. Should smell like burnt coolaid. I'd also check your exhaust. Lots of white steamy smoke means your burning the coolant off.
No puddles after it sits for a bit? Could be leaking only when the engines on. Let it idle and go leak searching. Check all the hoses. Look at where the heater core lines go through the firewall and see if its leaking there as well. They are on the passanger side behind the cylinder head.
Mines got a small leak somewheres too. Very small so its been hard to find, but I can smell it after a shut down sometimes. Very annoying.
Good luck!
I recently picked up a coolant pressure tester.
It sure makes finding coolant leaks easy.
Especially the small leaks
Put pressure on the system and wait for water to accumulate...
jason
Well, Ken the mechanic thought the heater core was in the engine compartment on 87-93 5.0's, but the floor isn't damp. I haven't driven it for a couple of days, but did notice yesterday around the top of the waterpump, what looked like it had been damp recently. Can't see any puddles underneath, because I like off a gravel road and it's parked in the wet grass. Can't smell anything from the exhaust end and it doesn't smoke at all. I haven't checked any of the hoses yet, but he has all that crap at his shop, so maybe we'll figure out what's leaking Monday afternoon? I hope it isn't a head gasket, because he said to replace both of them labor/parts was gonna be around $700 bucks.... That's a big letdown too, cause I sure as hell won't be repairing it anytime soon.
Place a sheet of plastic drop cloth on the ground and park on it. That will catch any leakage. No plastic sheet handy? Cut up a cardboard box and use it. A pizza box is just the right size.
The water pump has two weep holes on the housing for the pump shaft. One is on top and the other one is on the bottom. They drip coolant when the pump shaft seal starts to go bad.
Your door lock problem is probably a bad electic door lock actuator.
Follow this link to fix your door lock actuator problems http://bellsouthpwp.net/l/r/lrichker/Mustang_tech/door_actuator_fix/1_of_8_door_actuator.htm
Stuck with door lock actuators that don't work and don't want to pay the $50+ for a new one? Tried the junkyard ones and found that they last six months and freeze up? A new actuator for less than $5. Fix one side for $18, do both sides for only $25. I don't sell parts, I don’t make any money off of the upgrade, I just tell you how to do it cheaply and easily.
If you bought the car and have no mechnical talent or no interest in learning some mechanical skills, you bought the wrong vehicle. These old Mustangs need lots of things fixed after many years of abuse and neglect. Paying someone else to to the work will soon drain your wallet and exceed the purchase price of the car.
Your door lock problem is probably a bad electic door lock actuator. Follow this link to fix your door lock actuator problems. If you bought the car and have no mechnical talent or no interest in learning some mechanical skills, you bought the wrong vehicle. These old Mustangs need lots of things fixed after many years of abuse and neglect. Paying someone else to to the work will soon drain your wallet and exceed the purchase price of the car.
OK, first off, I didn't say I didn't have any mechanical skills, I said I didn't know much about the 5.0's or Fords for that matter. This is only the 4th Ford vehicle I've had in past 8 years: 55 F100, 98 Cobra Vert, 04 Edge and now the 93 GT. Now about my door problem, I can understand the actuator part, but is that also why I can't get the key to lock it from the outside? When I put the key into the door lock, the key is straight, try to turn it to lock it and it turns just a little before it feels like it's ready to snap off, thus not locking the door, would it be a bent rod inside the door?
no, the key lock is connected to the door latch with a rod. the lock solenoid (motor, whatever) is also connected to the door latch with a separate rod. however, they move together. so, if the lock motor is frozen, you will not be able to turn the key. :nonono:
Sorry about the misunderstanding. When you mentioned mechanic and money in the same paragraph, that conveyed the impression that you were not into doing repair work.
Follow the link, it will tell you how to remove the door panel and inspect the linkage. It takes less than 30 minutes and is simple to do. Removing the old actuator or disconnecting it is the way to find out if it is binding .
Oh, ok, thanks. GM's are totally different than Ford's. I ordered the actuators after I read his last post. My friends' 92 LX 5.0 is doing the same thing, sort of. When you push the power lock button, it doesn't lock, but it will lock if the key is used.
No problem. I just don't like venturing into the internals of an engine, if I have no clue what the hell I'm looking for in there... :rolleyes: Don't get me wrong, I would love to know how to fix it myself, engine/tranny wise. Now, if it's body, interior, susp., or mods, I have no problems at all. :nice:
Update on the coolant problem: I drove it to my dad's place this morning, we added more coolant and I finally got the "low coolant" to go off. I believe we've narrowed it down to the waterpump, hence the small bit of steam coming out from underneath it, after the Stang got warm.
Again, we checked the oil, looked normal. Checked the exhaust for white smoke, no smoke at all. Smelled the exhaust, no small, other than normal exhaust smells. Then, the last test drive down the road a couple of times and back, that's when we noticed the steam rising from the waterpump, so "fingers crossed", I hope this is the problem. Something else, the antifreeze was the color of dirt and down right nasty looking. So, once we establish if the pump is bad, I'm gonna flush the cooling system too. I have more questions about other parts of the car too, but have no clue where to start the threads at on this site? :shrug:
when youre viewing the threads in a forum, the new thread button is at the top left of the page. but what's up?
No, that's not what I meant, at least I don't think it is...? I meant, questions about body, interior, suspension, etc.? Is Stangnet the place to ask those questions or is this site more for engine/performance questions? Should I find another site to ask about other questions?
For example: Would it be better to replace my headlights/parking lights with new ones or is there some way to clean the crap off the inside/outside of the lens?
