Progress Thread Low Mile 89 GT Restomod - On to some cut and bufffing
We decided to go with hood struts instead of a prop rod. I pieced together something starting with a kit from a BRZ off Temu. The kit was about $30 CDN and included mounting brackets and 11" (extended) struts. I purchased an additional pair of 15" struts rated at 100lbs ($48 CDN) as the originals are much lighter capacity.
The Temu kit with the 15" strut at the top.
Had to drill out the upper bracket for an additional hole to attach to the top hood hinge bolt. The lower section near the middle hole needs to be ground back a little bit (1/8-1/4") and I then welded up the middle hole for strength followed by a quick respray of semi-gloss Tremclad paint.
The lower bracket comes with an offset formed in it. I needed to straighten it back out to fit where I wanted it.
Install is in the top hinge bolt and the lower attached to the middle fender bolt.
All finished it works well. It is not bad to lower and has almost no resistance trying to push up for the last 3-4" before fully closed. The last pic is with a prop rod mocked up to show it doesn't open as far as the prop rod would hold it, but I'm pretty happy with it. We will see how it is longer term with use.
Though not going on my son's car, but I picked this up last summer and decided to clean it up/repair it a bit.
A previous owner had the thought of enlarging the inlet - probably thinking it was needed for a 75 or 80mm TB.
They bored a nice straight hole that fits a 3" piece of exhaust or intercooler tube inside (perfectly), but broke through the cast near the throttle body mount.
Damn, that's one rare ass intake to, smooth side production intake limited to first 500 or so 93 cobras.
I picked up a replacement pair of door moldings as the originals were a bit beat up.
Passenger side curled down toward thee ground at the front.
Cleaned up the old adhesive from the rear.
Last couple of bits got painted red. The door moldings and one of the side skirt pieces.
Reactions: 85GT4V
With the red done, its time to focus on getting some trim painted.
20260919_090237.webp 20260919_090244.webp 20260919_090255.webp 20260919_090304.webp
With the masking removed...
Got the wheels and tires mounted up...
Couldn't resist putting one of the rear tires on to see how it looks.
Refinished one of my spare sets of quarter windows as the original passenger side piece had some kind of fading or water stain under the glass, on top of the black background coating.
Then temporary installed (so they don't get damaged sitting around the shop).
Pulled the car outside to give it a first bath post painting to clean the dust off before a cut and buff.
Then some post wash pics in the sun.
Roof and hood are pretty good but still some trash that needs correcting.
I had a bunch of runs in the clear on the hood. You can see some of the areas where I scraped with a razor blade. Still more work and I may have to re-clear the hood.
Reactions: gkomo and 85GT4V
I wanted to get the cut and buff out of the way so that I could permanently install the 1/4 windows and door seals and trim.
I first tried buffing only with a series of denim pads and a 3M Finesse It - Finishing Material compound.
It definitely improved the orange peel but the reflections were not good enough in my opinion in a bunch of areas so I decided to sand with 1500, 2000 and 3000 before re-buffing with the denim pads.
I did half the roof and the driver side fender, door and quarter panel. Still need to do the rest.
I got the hood sanded with 1500, but will probably still re-clear it as when I was scraping the runs I had one where the bubble at the end of the run popped completely off and it looks like in that small area all the clear came off. So probably a re-sand with 800 and two more coats of clear - next trip at the end of October.
I also got the door handles and upper door/window trim painted so they will be ready to go on once finished with the buffing.
