Low RPM jerking
Hey everybody, I recently purchased a 1990 Mustang 5.0 LX coupe. It has been Board over headers straight piped ex BBK 70 mm throttlebody Plenum spacer cobra intake . I have redone the vacuum lines. The car has been sitting for a while at wide open throttle. It seems to be OK but you can still feel like it’s holding back a tad. But higher gears trying to cruise jumps back-and-forth like it’s missing spark I got my timing set up about 14 cannot figure this out also has a E303 Cam someone please help!!!!
E303 bucks at 1,400 and below. This may be somewhat tuneable, as I've had it where I could lope along lower when I played around with things, but after more adjustments, it's bucking there and lower again. If you're at 1,500 RPM and above, then I'd say you're probably right about your concerns.
Reactions: Willybill32
@FastDriver, thank you for this comment! My ‘86 has an E303 installed and has a tendency to buck at 1500 and below. My assumption has always been the cam causes this. Thanks for your confirmation.
Bill
