just assembled my lower end with a reground 10-10 crank,recondicioned rods,new bearings(rods and main)new std pistons and new moly rings.oiled every part before installed.should the crank turn over hard or easy?
YES!! plastigauge, it costs 5 bucks, is accurate enough for a regular rebuild and its easy to do. measuring it with a mic requires a set of mics ($$$) and is not that easy to do (yes it's only taking measurments and adding and subtrackting to figure clearances, but its not easy if you dont know what your doing)PlastiGAUGE! Use a micrometer and do it right. Especially on a rebuild. If you just want to see if your bearings are still... Ok... after 60k miles then ok... use plastiguage. But for a new build use a mic to check true diameters.
