Lower intake manifold retorque
BaBiLuTH
48
Hey, I have an 88 5.0 and have a sorta weird question. My question is about torqueing the lower intake manifold. I am about to install Gt40 heads and Gt40 upper and lower intake manifold and am concerned about the torque. My friend and I replaced his head gaskets last week on his 5.0 and after I was done torqueing the lower intake manifold, I went to go recheck the torque with the torque wrench and found that the bolts had to be torqued again. I torqued them down and recheck and found that the passeneger side bolts were still not torqued but the drivers side ones were. I continued with the torque sequence again (never loosening the bolts, just continuing) and after rechecking again, I found the the passenger side bolts needed to be tightened again as the drivers side was tight. I did this step about 4 times all together and then just left the bolts alone. To me I dont think that the bolts were stretching or anything like that, should I have continued torquing or sound I have stopped? I dont want to run into this problem with my car but if I do what should I do? Please let me know as I'm starting this prject very soon. Thank you.
What were you torquing them too? I like 18 pounds for myself but opinions will vary. Best thing to do would be to back out all the bolts and begin by hand tigtening the bolts and going throught the sequence untill you reach the desired torque on all the bolts. Remember to retorque again at least one more time after a 100 or so miles.
04sleeper said:
I have found with Felpro 1250 or similar gaskets that you need to go over the sequence at least 5 times. Torque them down to 23 ft. lbs and you should be fine.
:Word: If you use the Fel-Pro 1250s and only go through the torque sequence once, you will not make it to the 100 miles. I know I didn't. When I finally got tired of putting oil in my car every week, I redid the tq sequence. I had to do it about 6 times before I got a good reading on all the bolts. Good luck.
