Lower RPM Miss
Synned
took tubgirl on a date and got banned
Mar 31, 2005
991
Philly
I have a miss that seems to be only at idle or lower rpms. Its weird because its not ALWAYS at idle....sometimes I don't feel a thing. I also hear a tick from the engine bay...and was thinking that it could be a plug wire arcing. Is this probable?
This miss is causing me to only run on 7 cylinders right? As soon as I gas it a little bit the imss disappears.
mine does that when the throttle is barely being touched, low rpm miss..... kinda like a jerk once in a while when in high gear....haven't found my problem yet, but looking at wires as well. they are taylors they better not have went bad that fast
jason
I guess the exhaust leak is a possiblity, but woudl that cause a miss? Theres a terrible vibration at idle. Its definetally a misfire, I just don't know why.
Are you running the stock manifold? If so then it probably isn't an exhaust leak.
I would pull the wires and visual check them out and take Volt meter and ohm out the wires. Stock wires should be around 1K or less I think. I would also check the plugs, and just take a wrench to the header bolts to see if any feel loose.
Well...changed the wires...still misfire. I also found 1 loose plug and tighteneded that but still a misfire...
I think the ticking is gone...I'll check later...prom is tonight. :)
