Ok here is my problem I recently had some suspension work done Eibach
pro kit springs, Bilstein shocks & struts, Steeda aluminum upper and lower
rear controll arms , steeda ball joints and bump steer kit, offset rack & pinion
bushings and maximum motorsports cc plates (installed 2 weekas ago). Obviously the car handles much better
But now I have a vibration in the drivetrain I believe, feels/sounds sounds alot like tire roar but only hapens when on the throttel as soon as you get off the throttle it goes away and comes back as soon as you get back on the throttle again not real loud kinda harmonic. My car is a 2003 GT automatic with no track time YET I have a chip (JMS) that corrected my speedo with gear install 3.73 (10 months ago) and has three settings all settings have improved shifts and the most agressive has pretty firm shifts my questions are as follows.
1) I run in the most agressive chip setting almost all the time, shifts even at low rpm's are firm and fast could I have worn out my U-joints already
2) Could my aluminum d/s be out of ballance
3) are there any aftermarket u-joints, upgrades = better than stock
4)Do carbon fiber drive shafts absorb more sound and vibration than aluminum
and are they lighter
Any help or suggestions on this would be greatly appreciated and remember I didn't notice this before suspension upgrades
THANKS
But now I have a vibration in the drivetrain I believe, feels/sounds sounds alot like tire roar but only hapens when on the throttel as soon as you get off the throttle it goes away and comes back as soon as you get back on the throttle again not real loud kinda harmonic. My car is a 2003 GT automatic with no track time YET I have a chip (JMS) that corrected my speedo with gear install 3.73 (10 months ago) and has three settings all settings have improved shifts and the most agressive has pretty firm shifts my questions are as follows. 1) I run in the most agressive chip setting almost all the time, shifts even at low rpm's are firm and fast could I have worn out my U-joints already
THANKS
