  • SN95 4.6L Mustang Tech
lowered Mustang
  • Thread starter Thread starter SonicGT
  • Start date Start date Apr 28, 2004
SonicGT
187
Ypsilanti, MI.
Apr 28, 2004
  • Apr 28, 2004
I recently lowered my Mustang 1.5 inches with Tokico Springs and Shocks/Struts and now there's a clunk coming from the rear when i go over bumps, have jack it up twice and no bolts are loose and nothing is hitting,the sound seems to be coming from the rear Shocks/Struts or Springs, all spring insulators are in right also ,check that twice, only thing i can see it to be is the top bolt of the strut, maybe i did not tighten it enough,how tight should it be. or maybe this is normal for high performance springs and shocks. Thanks for any help.
R
rjstaaf
1,310
Somewhere
Apr 28, 2004
  • Apr 28, 2004
Check where the Magnaflow Catback goes over the rear axle, it is probably hitting your sway bar on larger bumps.
R
Rocketman
730
SoCal
Apr 28, 2004
  • Apr 28, 2004
Did you change out your differential bump stop? When lowering you need a shorter one.
01GT eibach
1,075
Pittsburgh, PA
Apr 28, 2004
  • Apr 28, 2004
Check to see if the catback is hitting the sway bar. Some have had that problem with the Magnaflow. And I can't help but notice you have one.
Blackhawk257
Leesport,PA
Apr 28, 2004
  • Apr 28, 2004
Yea mine did the same thing, caused by my magnaflow catback hitting the sway bar
SonicGT
187
Ypsilanti, MI.
Apr 28, 2004
  • Apr 28, 2004
I'll have to check the sway bar and see if its hitting, do any of you guys know how tight to tighten the top bolt on the rear shock, i'm not sure if i have it tight enough.
D
damien2003gt
181
  • Apr 28, 2004
Yep! Turn it till it's tight.
03poontanggt
296
fresno ca
Apr 28, 2004
  • Apr 28, 2004
I have the same problem that your describing in my vert, the rear pass. side has a clunk on bumpy roads and speed bumps ect. It started right after the springs were installed
shaddixstang
66
Destin, FL
Apr 28, 2004
  • Apr 28, 2004
Had mine lowered and it did the same thing. Took it to a muffler shop and they took care of it for me. They had to adjust the catback.
Jon
~B7~
369
TX
Apr 28, 2004
#10
  • Apr 28, 2004
  • #10
I never had a clunk sounds, but while checking my exhaust one day I did notice that it had barely rubbed the rear sway bar a little (driver's side). I have a find a happy medium between for adjusting the exhaust between the sway bar and the gas tank though.
C
CatmanJJ
Captain Tangnet
20+ Year Stangneter
Feb 5, 2002
4,379
Maryland
Apr 28, 2004
#11
  • Apr 28, 2004
  • #11
I had the same problem when I lowered my GT and I have magnaflow exhaust as well. I think it just needs to be realigned to reduce the clunk over bumps.
F
flipnsac
159
Northern CA
Apr 28, 2004
#12
  • Apr 28, 2004
  • #12
Right on Rocketman! I had the same problem after installing my lowering springs and just grinded down the differential bump stop and the noise went away!
Mustang_1
49
Sturgis S. Dakota
Apr 28, 2004
#13
  • Apr 28, 2004
  • #13
Mine did the same thing to, I have Borla Catback, mine was hitting where the exhaust came over the rearend, you could see the rub marks on the exhaust, I heated the pipe up and used a ballphine hammer and added a relief contour on each pipe, no more sound
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
2K
Fox 5.0 Mustang Tech Apr 11, 2026
J
Foxbody mustang throttle body return spring
  • Jakub2537
  • May 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 18, 2026
86HO5.0
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
