I finally got my car so it can hit the streets again and I took it out of the driveway and things weren't looking to hot. I did the eibach prokit all around on my car and when I hit the brakes for the first time the nose dove down a bit and my tires rubbed HARD on the fender well. I have a 5 lug setup on my car with the sn95 spindles, Strange adj struts, all new a frame bushings, steeda x2 balljoints (spring lifts are in place), 235/45/17 tires, and the prokit as I previously said. Why the hell does my tire rub so hard? I do remember my stock springs having a bottom rubber boot on the springs which I decided to leave off since I've never seen them before... Could that be the reason why its hitting so hard? That still seems like it could be a help to have put back in but its not nearly and 1/8 of an inch thick, probably even less than that when compressed. Currently if 2 people jump in my car right now the tires are just about on the fender well. What did I do wrong?
When I did my springs I put the spacers that came with the x2's then the top bushing then the springs in the perch... why is this all bukaked and hitting my wheel well?
My plans are to go pickup a set of nitto 225/40/17's, adj the struts so they are rock solid, and pop that rubber boot back on the bottom but I still think it might hit... any ideas? Anyone else have this problem?
BTW my car needs an alignment also since I just put the kmember in and all new struts and stuff so that might also be part of my horrible rubbing problem also. Thanks for all the info though. :SNSign:
I just had it out during my motor swap... but when it was out the top plates with the caster settings got moved around so its all funky now.
