Earlier this spring, I had installed a new set of leaf springs which lowered my rear significantly (Maier Racing 160's). At the same time I added new coil springs up front... 1 inch lowering 600#. When all was said in done, my front was about 2 1/2 inches higher than the rear end as you can see below:
So, I ended up cutting the front coils to lower the front end to a reasonable level. I thought I would share my experience as I know cutting of coils comes up as a topic occasionally on this forum.
Using a Dremel and a fiberglass cut-off wheel (several of them as a matter of fact), I cut off half a coil. This dropped my front end almost exactly 2 inches. Here is a picture of the cut off coil:
As you can see for a comparison below... the ride height is much better (IMO):
I still need to drop about another 1/2 an inch and hope to accomplish this with the 1 inch Shelby drop. I definitely do not want to cut any more spring given that at full extension of the suspension with the car on jacks... the springs almost fall out.
So hears to hoping the Shelby drop doesn't let them fall out either!
Anyway, hope this helps someone out in the future.
Scott
So hears to hoping the Shelby drop doesn't let them fall out either!Anyway, hope this helps someone out in the future.
Scott
